I had strange noise when going downhill at around 1800-2000rpm. That was the clutch, had to replace the clutch pack
Over the last few weeks I started to notice a strange sound from the engine/exhaust in our Passat Tdi Alltrack DSG.
When driving up hills in second or third at approximately 2180rpm there is an unusual raspy sound (vibration like) it doesn’t seem to happen in 1st gear or 4th and above. It also won’t do it in Neutral.
video for reference.
YouTube
At first it was hard to get it to happen, but now it’s becoming far more noticeable. Doesn’t seem to happen on flat road or while coasting in gear downhills.
Second hand Dealer Purchased in January, I’ve got balance of new car warranty to roughly November. (I’ll check original QLD rego details)
Current: MY16 132TSI | Luxury | R-Line
MY14 C250 W205 | Command | Vision | Exclusive | Seat Comfort
MY13 A200 W176 | Command | Vision | Exclusive | Seat Comfort
Sounds like a harmonic vibration to me, not mechanical. Perhaps one of the mufflers has shaken its internals loose.
i’d take the video with me to the dealer if it’s under warranty. Main reason being, the dealer is the only one authorised to do warranty work. All you’re after initially is a diagnosis. Book in a time where the service manager can go for a drive with you to witness the issue - then there can be no response of “could not replicate”.
Perhaps it's the dreaded wastegate rattle issue that they never solved @ factory. The fix is a clip on the wastegate actuator. It might not be it, but I tend to suggest the common stuff first.
MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
