Results 1 to 5 of 5
Thread: Passat wagon windscreen dimensions
    Mar 2019
    Hi all,
    Wondering if someone with a Passat wagon might be able to provide dimensions of their windscreen? Width across top and bottom and height
    I have a Superb and wanting to see if they are the same or similar as I want to buy a custom sunshield which aren’t listed for the Skoda.
    Thanks
    2018 Skoda Superb Sportline Wagon (MY19)
    Dec 2017
    Forest Lake, Queensland
    aratic
    Across the top - 1240 mm
    Across the bottom - 1480 mm
    Top to Bottom Left - 775 mm
    Top to Bottom Right - 775 mm
    Top to Bottom Centre - 865 mm
    The above are only approximate as some are hidden under plastic on the side
    top and bottom are corner to corner but windscreen is curved out
    My car is a Passat RLine 206 Wagon MY18
    Hope this helps
    Regards
    Paul
    Mar 2019
    Quote Originally Posted by 5paul0 View Post
    aratic
    Hope this helps
    Regards
    Paul
    Thank you Paul!
    Are those dimensions taken from the outside of the car rather than inside?
    Dec 2017
    Aratic
    Yes, they are take across the outside of the screen.
    Out of curiosity, how do they match with the Superb.
    Mar 2019
    Aratic
    Paul,
    My dimensions are:
    Across the top - 1180 mm
    Across the bottom - 1400 mm
    Top to Bottom Left - 670 mm
    Top to Bottom Right - 670 mm
    Top to Bottom Centre - 680 mm
    I couldn’t get an accurate measurement using a builders measure so used string and cut it to length for each.
    I would note that I am looking for the dimensions within the clear part of the glass ie excluding blanked out parts) as it’s for an interior rigid sunshade.
    Thanks again for your help.
