Results 1 to 9 of 9
Thread: Passat R (MY18) DSG minor issues
    Jun 2019
    NSW
    Hey all,
    I have tried searching this but haven't come across any info and wanted some advice and to hear if others experience these issues before getting checked out.
    As per title I have a MY18 Passat R and I drive the car in manual mode most of the time. When going at slower speeds (around 20kmph) if I go from second gear back to first gear there is often a massive delay in the engagement of the gear (1-2 seconds) which I have found can be dangerous if there is on coming traffic for example.
    Can anyone else confirm if they are having these issues. Should I be getting this checked under warranty at a dealership.
    Appreciate any input or others experiences.
    Cheers!
    Apr 2017
    Quote Originally Posted by sinstr View Post
    Hey all,
    Cheers!
    You should use 1st gear after take off. It’s DSG first gear protection.
    Apr 2017
    belgrave victoria
    Quote Originally Posted by zzc2010 View Post
    Yep 1st gear normal only will engage at a standstill so its a delay to match the speed your going so no damage happens
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Jun 2019
    NSW
    Thanks for the clarification. That makes sense. It threw me off a bit as sometimes it has the delay and other times it works perfectly.
    Cheers!
    Sent from my SM-N950F using Tapatalk
    Apr 2017
    Cheers!
    Not sure if you’ve driven a manual car. The revs need to be matched in between the gearbox and the engine if you drive it hard. Each time you downgear, the revs jumps higher and it delivers more power. However, drastically more heat for the transmission to handle when you smash it.
    Pacific Paradise QLD
    Why buy an auto and drive it manually Obviously the box knows more than you LOL
    Jun 2019
    NSW
    Yep I have owned multiple high powered manual modified cars (gtr, evo etc) so I understand what you mean. In these cases I'm rolling into a roundabout for example at 10-20kms and looking to exit quickly hence the reason I'm knocking it back to first. After some testing this arvo if I leave it in 2nd and exit quickly it puts itself back to first anyway which is fine Passat R (MY18) DSG minor issues I'll just adjust how I drive and it will be all good.
    Jun 2019
    NSW
    I much prefer driving it in manual, in auto it takes time for it to kick back gears whereas manual you can preset the gear for what you want to do.
    I'm sure others here are the same Passat R (MY18) DSG minor issues and besides you cant get the Passat 206 in manual hehe
    Mar 2009
    Melb
    what I do with mine when approaching a roundabout or tight corner is pop the gear into sport mode.
    Tig 162 R-Line; Audi TT
