Results 1 to 5 of 5
Thread: Passat B8 sedan boot dimension
    Feb 2017
    Hi everyone,
    Does someone know what is the height of the boot space in Passat sedan?
    May 2007
    From a VW Passat (Aus) Brochure / Specification Sheet;
    Luggage are volume (L): 586L (sedan) / 650L (wagon)
    Load height (mm): 507mm (sedan) / 890mm (wagon)
    If you want a copy of the spec sheet, PM your email and I will send to you.
    Feb 2013
    Perth, WA
    Quote Originally Posted by rave75 View Post
    Hi everyone,
    I'll try and remember to measure mine. What part do you want measured? Boot floor to highest point internal or the opening diameter?
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
    Feb 2017
    Quote Originally Posted by Wynnston View Post
    Boot floor to highest point internal. Thanks a lot!
    Feb 2013
    Perth, WA
    Ok. I've just measured it
    It's 50cm from boot floor to the top of the inside. Allowing for things like the bag hook which you'll foul on if you put anything higher than 50cm in.
    About 15 cm's back from the back seats in the boot, it steps down to 46cm, most likely for the main rear structural beam.
