Results 1 to 7 of 7
Thread: passat b8 engine noise on start up
    Aug 2021
    Smile passat b8 engine noise on start up
    Hi Guys I'm new to the forum and would like some advice - I have a
    Passat 2016 B8 TSI with engine noise on COLD start up (42,000km).
    Whirring sound from engine bay.
    It does go away after a few seconds with the car idling & doesn't appear again for the entire day until the engines cold again.
    I've taken it to VW and they've said its normal operational but I'm a little scared its timing belts or something grinding.
    I haven't heard the noise on other Passat's or Tiguan when test driving from dealers.
    I can share the video of the noise you can clearly hear it about 5 times.
    https://youtu.be/AykrJJVCsHI
    Last edited by psstnoisey; 29-08-2021 at 10:49 AM. Reason: better video of problem
    The sound at 3-4 seconds is normal (as in my Golf with EA888 2.0 T engine does the same thing on a cold start, and I have heard others do it - its just the sound of the timing chain until some oil pressure builds up) but the sound that comes and goes at timestamp 5-7 seconds is odd.
    It may or may not be something to be concerned with. VW will say its "normal" because they are only interested in raping your wallet once something actually breaks. Best take it to an independent VW specialist to be looked at. Where in Melb are you?
    Jan 2013
    Hi
    You didn't mention if you have tsi or tdi. Not sure about tdi, but tsi do not have timing belt. I have b8 tsi and i can usually hear engine only on startup. After it, engine pretty much makes humming sound which barely can be heard.
    If you still not happy about it, i would recommend you to visit guys from volkswerke - Doncaster.
    Sent from my SM-G986B using Tapatalk
    2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
    Quote Originally Posted by saint70 View Post
    You can hear its a petrol engine (TSI).
    Jan 2013
    You are right, i didn't listen file passat b8 engine noise on start up
    Aug 2021
    TSi engine so not Diesel. I'll need to get at looked at.
    thanks
    Aug 2021
    yeah Melbourne, western subs.
