Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 121 to 130 of 133
Thread: Passat Alltrack Wolfsburg
  1. #121
    Jun 2011
    I’m on the scope for a second hand one. My B7 is likely a write off with major hail damage. It’s insured for just under 27k and can get into a B8 alltrack for around 33 or the cheapest Wolfsburg I’ve seen at 40k
    It’s a hard decision as I loved the pano roof and paddle shift of our sport pack equipped B7 but you can’t find those options together on the standard B8. A pity I can’t afford new as there’s only 4K price difference.
  2. #122
    Jun 2011
    Is the DCC in the Wolfsburg different from the drive selection modes in the standard alltrack?
  3. #123
    Mar 2017
    Tasmania
    Quote Originally Posted by Foxpuppet View Post
    Dunno what the standard Alltrack has. Drive modes in the Wolfsburg change steering, suspension (dampers), transmission, and throttle response. Also climate control and cruise control.
    Dec 2018
    Still under 7000km and had two check engine lights come in in the last 2 months.
    Both for the same issue. P20ee Catalyst Efficiency Below Threshold.
    First time I took it back and was advised that it was an AdBlue metering issue. Advised to drive car in Sport mode and be a little vigorous with our driving in that mode.
    2 months later get the light again with the same fault code.
    Took it back again. Advised that the issue would be referred to head office. Called back to advise that there is a new ECU update for the car.
    Advised that the fault should not reoccur.
    This was on top of the rearview mirror resin having failed. Resin was running inside and over the auto wipers sensor - auto wipers unusable. Next day was a 42° day and the rearview mirror came completely loose.
    Hope all good now. Fingers crossed.
    Still love this car.
  5. #125
    Jan 2014
    Narangba, QLD
    DPF regeneration
    Hi,
    Just wondering how often everyone else finds their Alltrack doing the DPF burn? Mine did it twice last week, only 400km apart. Considering half my km are highway I didn't expect this to occur so often. My wife's Golf 110TDI doesn't do it anywhere near as often.
    Thanks,
    Karl
    MY18 Passat Alltrack Wolfsberg (white) darkest legal tint (SOLD), 2014 Golf 110 TDI Highline (sold after DM Flywheel issues), now 2021 RAV4 Cruiser Hybrid, 2020 C-HR Koba Hybrid
  6. #126
    Apr 2010
    Hi Karl,
    Mine seems to do the same. Approx every 400km (with 30,00km on the odo).
    Doesn't seem to make much difference whether I do highway or urban running.
    What frustrates me most is that I can do a 2 hour run on the freeway, and then 10 minutes after I get off the freeway, it starts to do it's regen.
    Had VW service check it out at the last service: all within specs (of course!).
    Previous Passat Diesel (2010 125kW) used to only do a regen every 1000km or so)
    MY17 Passat Alltrack Wolfsburg, Indium Grey, Sunroof
  7. #127
    Jan 2014
    Narangba, QLD
    Gazza,
    Thanks for that. Yeah it's frustrating how it lacks any intelligent programming. I've had it try 3 times on short trips and then do it again on the next longer trip because it never completed. At least it's "normal"
    Cheers,
    Karl
  8. #128
    Mar 2017
    Tasmania
    Mine seems fairly regular - although I don’t take much notice admittedly.
    There’s little point in comparing with what previous generation vehicles behaviour was because the Euro 6 programming will result in different emissions equipment behaviour compared to previous gens.
    Jan 2014
    Narangba, QLD
    Refill amount
    Hi All,
    Another question, what's the most diesel you've refilled? Yesterday I had range showing 30km and filled, it took 64.9 L, I'd done 1082km just commuting not a highway trip. Just curious as to how much was actually left in the tank, I'd heard rumours that despite the brochure saying 66L it was actually 70L.
    Thanks,
    Karl
  10. #130
    Mar 2017
    Tasmania
    Dunno the actual volume, bu if the brochure says 66L, then knowing VW that will be the ‘usable volume’. Total volume will be a bit bigger because there needs to be volume to spare for when the fuel expands in the hottest climates. Usable volume also doesn’t necessarily include a few litres that - depending on which way the vehicle is leaning, may not be able to be scavenged by the lift pump.
