Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
Thread: Passat 206TSI Oil Usage
    Feb 2015
    Sydney, Australia.
    if the dealer is topping it up with VW OEM CASTROL then that is probably your issue.
    If you get 504.507 spec penrite enviro+ or shell you will be good.
    been through this with the R which obviously has the same motor.
    i was burning 1/4 - 1/2 my oil every 1,500 - 2500km but that stopped happening when i started using either of these oils.
    then to test i bought another bottle of castrol after many KMs of using the others and again it burnt alot faster.
    penrite is usually on special at supercheap or repco , usually 60 per bottle. shell you can get on ebay for 75 per bottle
