Originally Posted by
Riker
The steering on R-line Passats is a progressive variable ratio just as in Golf GTi, R etc. Turn in is quicker than B6-B7 Passat & lock to lock is certainly less ie variable ratio..
I guess the critical difference is the steering of a B6 Passat seems to be a fraction under 3 turns lock-to-lock - say 2.9.
If a B8 R-Line is 2.1 turns, then it would be a significant improvement for someone who wants quick steering ... although a variable ratio would probably mean the steering would be no quicker for the first 1/4 turn or so away from centre.
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
