Page 33 of 78 FirstFirst ... 23313233343543 ... LastLast
Results 321 to 330 of 776
Thread: New Passat 206TSI R-Line
  1. #321
    Quote Originally Posted by SciroccoJ View Post
    Does it induce any noise from the exhuast/engine? (just want to see if it will pass the daugther/wife test, aka... sneak it in without them knowing)
    It sounds exactly the same to me. Obviously under heavy acceleration there is engine/exhaust noise but I would challenge anyone to tell the difference.
    The car drives much as it did before with moderate throttle control which will be the give away if moderate throttle control is not used.
    ......It is however noticeable when the installer of the JB1 puts their sticker on the back windscreen. That's how I was sprung!
    Sent from my SM-G930F using Tapatalk
  2. #322
    Jul 2013
    Quote Originally Posted by AZ_Wagon View Post
    Awesome! and $699 installed is a great deal. It cost pretty much the same landed here in australia when you added the data cable and shipping....
    MY13.5 Rising Blue Scirocco R - DSG - Sunroof - sold!
    MY15 Pearl Black Tiguan 155 R-Line - DSG - Dual Sunroof - SatNav - Leather - sold!
    MY17 Indium Grey Passat 206TSI R-Line Wagon - DSG - Dual Sunroof ... the Journey Continues ...
    Check out my blog for car photos and product reviews! http://www.infiniticious.com
  3. #323
    ......please give them a call first if your going to Hill Eurohaus. I think I got the last one in stock and they were going to wait for the JB4 to be available rather than order more JB1's. Hills are going to upgrade mine to a JB4 when the firmware update is available.
    Also, if you are going to use Hills Eurohaus, give me a shout as I work across the road!
  4. #324
    Nov 2016
    VIC
    Anywhere in VIC that sells it?
  5. #325
    Nov 2016
    VIC
    Also does anyone know if you can get the rear sun shade inserts like you can get in the Tiguan? They sit nicely flush in the back windows and great if you have kids back there. They sort of click in around the window frame
  6. #326
    Feb 2013
    Perth, WA
    Has anyone done any VCDS tweaks yet?
    So far I've
    - Enabled Traffic Data
    - Enabled Sign Recognition (not that fantastic in AUS because our signage standards are terrible)
    - Permenantly disabled stop/start
    - Enabled needle sweep on startup
    If anyone wants to do any of the above and needs some tips then I'd be happy to do up a quick how-to. Obviously a VAG-Com Cable and VCDS is required.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
  7. #327
    Oh wow. Would love to have these tweaks done to my*car. Anyone in Sydney /*North Ryde that can help out?
  8. #328
    Jul 2013
    Quote Originally Posted by Wynnston View Post
    So far I've
    Wow... thats impressive.... I dont know if my old cable will work on the new passat (it works on the 2015 Tiguan I had).
    Can the Start/Stop be programmed to be off by default (but you could still switch it on if you want to) instead of disable permenantly?
  9. #329
    Nov 2016
    VIC
    Thats cool!! How does the traffic data work?
    Video on needle sweep pls!!!
  10. #330
    It should work - it's the same comms interface and you just have to make sure your Vagcom software is up to date.
    Start/stop is disabled by adjusting the min battery voltage required to go into start/stop (car won't do stop/start if your battery charge is low). So if you set the min voltage to (say) 14V then the battery will never achieve this and so car will never go into start/stop.
    Otherwise you have to press the button to deactivate it every time you drive. Start/stop was suspected to have had some part in premature turbo failure in a number of earlier MQB platform cars as hot turbos were stopped (by start/stop) instead of gently running (idle).
