Yes have the tow bar on mine, you can adjust with the set / res buttons for 1kph increments
I hope the following helps...
1. Check some of the earlier posts... some of the owners have had dealer fitted towers fitted.
2. It helps you launch the car to achieve the min 0-100 time. I don't know how to operate it... nor would I ever do it. She launches just fine in Sport mode.
3. No... but shop around. I've used NRMA Service centres before. All the same gear, same quality bout about 25% cheaper. Get quotes!
4. Yes. The set/resume buttons act as +-1km/hr when it's activated and set. The silver + & - buttons shift the bug in 10km/hr increments.
5. I tinted my sunroof. I was going to stuff insulation (Kingspan Aircell) in between the glass and the blind... but the tint is doing a great job of keeping the heat out. I believe this is a must if you're getting the glass roof.
6. I just tried it. The windows close... but the sunroof remains open. Looks like it's accurate!
7. Depends on how well you can negotiate. Could be possible for the sedan... probably not the wagon! Give it a shot though!
Now - MY17 Passat 206TSI Wagon - Tungsten Silver | Sunroof
Previous - MY11.5 GTI 5Dr - Reflex Silver | DSG | ACC | Sat Nav | RVC | Bluetooth | MDI | 18" Detroits | Park Assist | Bi-Xenon's | Leather | Sunroof | R-Tails
Just to add...
for Launch Control - Yes, it does have it. You need to long press the traction control button to disable it completely, put your gear in to sports, left foot on brake, right foot pinning the accelerator to the floor, it will help you to keep the rev at around 4k mark, then release the brake once you are ready to take off!
For the convenience close feature, I am pretty sure you could programme it back using VCDS.
J
MY13.5 Rising Blue Scirocco R - DSG - Sunroof - sold!
MY15 Pearl Black Tiguan 155 R-Line - DSG - Dual Sunroof - SatNav - Leather - sold!
MY17 Indium Grey Passat 206TSI R-Line Wagon - DSG - Dual Sunroof ... the Journey Continues ...
Check out my blog for car photos and product reviews! http://www.infiniticious.com
MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
I can confirm the Tiguan with the 7 speed DSG has LC. It has been tested a couple of times...
Just now went for a test drive in a 206 sedan with a tuning box and tested LC. It definitely has LC. And wow did it launch.
Important to have it in Sport.
HOLD the T/C button till you see the second message come up and then do the thing with the brake and accelerator.
Sent from my SM-G930F using Tapatalk
