Results 1 to 5 of 5
Thread: Need to run some wires through the firewall
    Apr 2018
    NZ
    Need to run some wires through the firewall. What's the best way to do it? I want the wires to end up at the fuse box under the glove compartment
    Aug 2021
    If you pull some of the carpet back up near where it meets the glovebox, there's a rubber grommet which can be pierced to accommodate wiring. This is how the OBD2 wire for a JB4 is typically routed.
    It's a bugger to get to though, and you will ideally need to create a small slit in the grommet to pass the wiring through. A metal coathanger or similar stiff wire is useful to help draw/push the wire through the hole.
    The wiring will pop out behind the battery. It can be fiddly to reach - two people (one wiggling from inside the cabin and one waiting with a torch from the engine bay side) makes the job easier.
    Aug 2021
    Even better... a walk-through with pics! This applies to the Passat too.
    Running Cables Through The Firewall – Volkswagen MK7 Golf – AutoInstruct
    Apr 2018
    NZ
    Excellent. Thank you very much petemac110.
    Apr 2018
    NZ
    Just to note on my rline Passat, which has the battery in the boot, I found it impossible to add sealant on the engine side of the firewall as it is very hard to get you hand in where the cable comes through.
