It sounds like in ECO mode but in D mode or like a Golf driving.
65k 7th gear.
What’s wrong with your mechatronics?
Did they replace the part but didn’t do a adaptation or coding the part to a Passat?
I’m sure a golf and a 132 share the same dry DSG.
I’m assuming the mechatronics is changing the gears for a golf not a Passat.
Driving with D in a Passat is different from a Golf as I owned both. The Passat holds revs much more and more engaging.
