Page 14 of 16 FirstFirst ... 41213141516 LastLast
Results 131 to 140 of 155
Thread: Map updates
  1. #131
    Pacific Paradise QLD
    Quote Originally Posted by Just_Westy View Post
    For the life of me I cant get this to work, feel like a dummy as I upgraded it early 2018 but now coming up with an error when trying to load this into car.
    Could someone please list the download, extract and update procedure for dummies.
    Click on the link It will bring up a box with a file name int it and asking if you want to save it or open it, Save it When you have done that go to location and Unzip it to a folder on your HDD
    Get an SD card with 32 GIGABYTE CAPACITY Make sure its formatted in FAT 32
    Copy the folder you unzipped it to onto the SD card
    Put it in the DISCOVER PRO and tell it to update.
    If you have a MAC that you are trying to do it on Chuck it in the bin and use a PC
    Simples
  2. #132
    Apr 2018
    Thanks Hillbilly, i've just been unzipping it directly to an 80gb SD card and it's in EX-FAT.
    Ok will reformat and extract to HDD then copy on FAT-32 SD.
    cheers
    Passat Alltrack Wolfsburg Edition My18
  3. #133
    cheers
    Try it with that it might work as it seems some reckon it does Where did you get an 80GB card thats a weird size and it wont format as Fat32 without a special formatting program as Fat 32 only works in Windows up to 32GB cards
    Also are you using a PC or a Mac
    You should have 2 folders named Mib 1 and Mib2 and a file named Metainfo.2text in the root directory of the card
    You can extract it directly to the card OK
    If you use Discover Care it does all that directly for you
  4. #134
    Apr 2018
    My bad it is a 32 GB card but apparently not big enough when I try and unzip download into it now comes up with an error and says not enough space on disk. Disk space is 29.7 gb free.
  5. #135
    32 gb card IS big enough as I downloaded that file onto one this morning to see if it would do it right Are you sure that like another poster it isnt a 32 MEGABYTE card instead of a 32 GIGABYTE card
    What machine are you using because MACS cause more problems than they are worth
    My card says 28GB used 1.8GB free
  6. #136
    Apr 2018
    No dice it's still saying : "Error: no data available please insert a source with software. or check the source"
    Used a windows 7 machine this time and Fat32 as ive downloaded the file onto 2 different machines. For some reason I get a size error using the win10 machine.
    I have the correct files downloaded Mib1, Mib2 and Metainfo.
    I suspect that the Scandisk is the issue but i'm sure I used a similar one last time.
    I'll pick up another SD card on the weekend and give it one more shot and if it doesn't work just wait for the next update. Thanks for your help.
  7. #137
    It definitely works Buy a 64GB card then and put it on that Sandisk arent always the best but i have an old 128 gb one that I also put the map on and it loads in the car. You do have a DISCOVERY PRO. dont you
    Cant work out why it doesnt work as I havent had any trouble using any of several make of cards. I have a WIn 10 machine
    Data for card Used space 30,124.523.520bytes 28.0GB
    Next map will be June usually
  8. #138
    Apr 2018
    It's a Discover Pro with the 9.2" screen.
    The problem has to be the SD card i'll get a different one.
  9. #139
    Jun 2007
    Sydney, Australia
    I had a similar issue a while ago with the message "Error: no data available please insert a source with software or check the source". Turned out to be a download issue with the file not the SD card.
    My download missed some files so I retried another go, looked over the file size and numbers and noticed a slight difference.
    I now use a 3rd party download program as my internet speed is still trying to cope with Y2K.
    Flipper Dog
    Now - T-Roc R, Audi Q5
  10. #140
    Feb 2015
    I use Xtreme download Manager, as I had the same problems each time previously. Downloaded first time last night, loaded in car on the way to work. 64GB SD Fat32
    Passat Alltrack Wolfsburg 2017
