Well, my plan now is to install P76 using DiscoverCare and see if it works.
Well it should work as thats what I had to do when it wouldnt work It only finds stuff in the root directory and if you have say a folder
called ROW79 and extract into that you have to open it and copy the shown folders and the file onto the card.
I didnt the first time and it couldnt find anything so I went back to the ROW76 card I had and looked at how it was.
I did it like i posted and it worked. I actually just copied it onto a card with stuff on it and it found the folders Ok and installed the update.
If you use Discover care it formats the card first
Nick
Passat 206TSI R-Line (MY17)
Looks like it was Mac related issue after all (regardless me deleting all hidden folders).
I've put the card into Windows laptop, full format, re-downloaded the maps, unpacked and copied into the card.
Glove box SD 1 slot, maps update has been recognised and completed in about 45 minutes.
Nick
I'm trying this for the first time, but when I go to the link, it only offers me European maps, and downloading the Windows app only seems to allow European maps as well (unless 'Multi Region Map' means ROW)
MY07 2.0TDi Comfortline in Black
The site is currently experiencing issues with ROW maps for Discover Pro units, unknown when it will be back and running again.
Flipper Dog
Now - T-Roc R, Audi Q5
Use this Its from the Map Update Thread In the TIGUAN MKII forum.
Look around the NAV units are the same across most of the MQB platform so look in the Golf and Tiguan forums for stuff
https://redirect.viglink.com/?format...S5MIBH3_ROW.7z
Anyone running into the issue with the Active Info Display? For me, ever since i upgraded my AID says "starting map".
Ive attempted to reset the headunit, factory settings, run the update again and make sure the maps is running.
Hoping im not the only one!
Passat Alltrack Wolfsburg Edition My18
