Page 13 of 16 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 155
Thread: Map updates
  1. #121
    Pacific Paradise QLD
    Quote Originally Posted by oj4rec View Post
    yes, the content is in the root.
    Well it should work as thats what I had to do when it wouldnt work It only finds stuff in the root directory and if you have say a folder
    called ROW79 and extract into that you have to open it and copy the shown folders and the file onto the card.
    I didnt the first time and it couldnt find anything so I went back to the ROW76 card I had and looked at how it was.
    I did it like i posted and it worked. I actually just copied it onto a card with stuff on it and it found the folders Ok and installed the update.
    If you use Discover care it formats the card first
  2. #122
    Jun 2019
    Melbourne, VIC
    Well, my plan now is to install P76 using DiscoverCare and see if it works.
    Nick
    Passat 206TSI R-Line (MY17)
  3. #123
    Jun 2019
    Melbourne, VIC
    Looks like it was Mac related issue after all (regardless me deleting all hidden folders).
    I've put the card into Windows laptop, full format, re-downloaded the maps, unpacked and copied into the card.
    Glove box SD 1 slot, maps update has been recognised and completed in about 45 minutes.
    Nick
  4. #124
    It does pay to say what you trying to do it on as Macs cause more angst than enough when you dont say thats what you are using
  5. #125
    Jan 2010
    Albury/Wodonga
    I'm trying this for the first time, but when I go to the link, it only offers me European maps, and downloading the Windows app only seems to allow European maps as well (unless 'Multi Region Map' means ROW)
    MY07 2.0TDi Comfortline in Black
  6. #126
    Jun 2007
    Sydney, Australia
    The site is currently experiencing issues with ROW maps for Discover Pro units, unknown when it will be back and running again.
    Flipper Dog
    Now - T-Roc R, Audi Q5
  7. #127
    Use this Its from the Map Update Thread In the TIGUAN MKII forum.
    Look around the NAV units are the same across most of the MQB platform so look in the Golf and Tiguan forums for stuff
    https://redirect.viglink.com/?format...S5MIBH3_ROW.7z
  8. #128
    Jul 2017
    Lalor, VIC
    Anyone running into the issue with the Active Info Display? For me, ever since i upgraded my AID says "starting map".
    Ive attempted to reset the headunit, factory settings, run the update again and make sure the maps is running.
    Hoping im not the only one!
  9. #129
    Quote Originally Posted by shonggie View Post
    WHat did you do to update the AID
  10. #130
    Apr 2018
    For the life of me I cant get this to work, feel like a dummy as I upgraded it early 2018 but now coming up with an error when trying to load this into car.
    Could someone please list the download, extract and update procedure for dummies.
    Passat Alltrack Wolfsburg Edition My18
