hi doc_777 i tried to update my sd card on imac, it was going ok; and when i completed update on imac, and put sd card into slot in car, and it could not find the update??? Passat B8 MY2016. Current version vo3959801E 0049 row 2015/2016.
should i buy a separate sd card, like 32gb class 10? or just keep using the sd card supplied by vw, however it is only 9gb per the info on my imac.
thanks heaps.
HIS: MY2016 VW Passat B8 132 TSI, white
HERS: MY2018 Kia Carnival Sli 3.3 V6, black
I just use the VW updater “DiscoverCare” - has a download manager included and also takes care of card formatting etc. Unzipped size of the file package is ~29GB
in the past I’ve downloaded the compressed file, unzipped it, and written it to card without using DiscoverCare - sometimes it works, sometimes it doesn’t. Using the DiscoverCare app i’ve never experienced a failure on MacOS.
good point; just got a 32gb sd card from officeworks; will have a go this arvo. thanks
still not working.
i tried use the new 32gb sd card, the headunit can detect the software update, however the 'start' button is inactive, and some files show 'Err' at the end, some show 'F' ... confused. did i download the wrong map? maybe?
anyway i use android auto often, gps map is not that important to me, just because it is free so i give it a go.
btw how can i have live traffic update on the gps?
just checking i got the right map material.
i am bit confused, should i still use the original sd card provdied by vw? do i need to update the original sd card on DiscoverCare? what's point to keep this original sd card?
if i want to update my map on car gps, can i just use the 32gb sd card loaded with new map material?
i just give up...
called dealer, my car is still under warranty, they can do map update for me free of charge... lucky this is the last year (3rd).
Being new and apologise in advance if I might have missed a previous post with the information I seek:
Own a 2015 Touareg with RNS850 infotainment system. Will the maps updates you used work on my vehicle and if so, what do I need or need to know to accomplish this?
Thanks in advance for all help and suggestions.
Vic Bliz (newbie)
Dont think so they use a different system and usually has to be done by a stealer at great cost
Try this forum as is model specific
Australia & New Zealand - Club Touareg Forums
Or here
RNS850 2018 Maps 6.26.1 - Page 3 - Club Touareg Forums
