Results 1 to 10 of 14
Thread: Passat B8 headlight upgrade
    Jul 2020
    I have a Passat B8 2016 & I’m not happy with the headlights, they are not bright enough. Any suggestions will be greatly appreciated.
    Pacific Paradise QLD
    Quote Originally Posted by Hamed View Post
    Well which ones have you got Halogens or HID
    Jul 2020
    Halogens
    Halogens
    Well to go to HID as in the Highlines is about $4000 to do it legally So some Phillips hi outputs are the best you can get
    May 2007
    The B8 Passat does not have HID Headlights (or what I would refer to as Bi-Xenon Headlights for low and high beam).
    3 options available (depending on trim levels); Halogen / LED (low-line version) and LED (Hi-line version).
    Hamed would possibly own a Comfortline / Highline (without Luxury Pack).
    Jul 2020
    Hi I own a Comfortline. Thanks
    May 2007
    Nice mate.
    There should be a few options for you for bulb replacement.
    However for the sake of other motorists, if you are going to go down the road of changing headlights etc, please ensure you do it properly to ensure the safety of not only yourself, but the other road users. Quite a few posts online regarding replacement headlights / washer units / level sensors etc.
    Jul 2020
    Thank you, I think I will go with the bulb option instead of changing the headlights.
    I might be able to do it myself ?
    May 2007
    It is a H7 Bulb that you need.
    Here is a good Bulb Finder site: Automotive | OSRAM Automotive
    Jul 2017
    Lalor, VIC
    Im actually interested to hear if anyone has done the LED Reflector upgrade to the LED lens unit (one with dynamic light assist where it shutters out cars). bit annoyed how the Wolfsburg edition comes with the garbage LED refletor lens
