Will try again today then and re download on a different machine, i'll get back in a few hours.
cheers
Printable View
Didn't work again, I ordered a new SD card and will use a download manager next week and try again.
Thanks for the help guys.
My bad, i was ment to say updated my map*
hi all, my first post. Had finally managed to update the system after lots of tries. Sharing my experience and hope it would help people.
From my experience, I used two different SD cards (class 10) of different brands (Sandisk and Lexar). It made no difference (both failed). I tried different formats (FAT32, exFAT and NTFS) using both Mac OS and Win 10, this made no difference (i.e. all failed). Tried WINRAR on Win 10 and RAR extractor on Mac, failed. Tried a USB, with all the above tricks, failed. Tried to access secret menu by holding Menu button on the unit, which allowed me to see folders and files, failed. Tried using either MIB1 or 2, failed. I was frustrated almost to the point of forking out $$$$ for a dealer, but sanity hadn't left me after weeks of ISO.
What worked was using 7-ZIP on window to extract the file directly onto a USB (FAT32 format). Copied 2 folders and txt file to the root folder. It worked flawlessly. Took about an hour to update.
There is a new map on the Skoda portal but you might need a valid VIN to download it it is Ver 88 but still has current from Nov 2019 but that one was 85
Installed and working
See this post for link to it courtesy Flipperdog
https://www.vwwatercooled.com.au/for...ml#post1315342
