It's the big one (24GB).
Nick
Passat 206TSI R-Line (MY17)
It's Passat not Tig ... but yes the archive looks to be correct. Extracted and copied as required.
As I said, when inserting the media into unit it says update is available, while update button in setup can't find it.
Nick
yes, the content is in the root.
Nick
Well it should work as thats what I had to do when it wouldnt work It only finds stuff in the root directory and if you have say a folder
called ROW79 and extract into that you have to open it and copy the shown folders and the file onto the card.
I didnt the first time and it couldnt find anything so I went back to the ROW76 card I had and looked at how it was.
I did it like i posted and it worked. I actually just copied it onto a card with stuff on it and it found the folders Ok and installed the update.
If you use Discover care it formats the card first
Well, my plan now is to install P76 using DiscoverCare and see if it works.
Nick
Looks like it was Mac related issue after all (regardless me deleting all hidden folders).
I've put the card into Windows laptop, full format, re-downloaded the maps, unpacked and copied into the card.
Glove box SD 1 slot, maps update has been recognised and completed in about 45 minutes.
Nick
Use this Its from the Map Update Thread In the TIGUAN MKII forum.
Look around the NAV units are the same across most of the MQB platform so look in the Golf and Tiguan forums for stuff
https://redirect.viglink.com/?format...S5MIBH3_ROW.7z
Passat Alltrack Wolfsburg Edition My18
