Originally Posted by
Goublin
Hoping someone on the forum may be able to help:
Car was given final tune last night. The TTE470 was fitted 4 weeks ago but we had a fuelling issue. I bought an autotec HPFP that we thought would solve this. It did make a little difference but running out of fuel near the top end (making excellent mid-range); we speculate that it could be either the injectors or the LPFP.
Being a Passat, the ECU operating system is different to the golf. We also speculate that VW (bless them) may for example put a different LPFP on the Passat to a Golf R. For example, although the same engine, they may put Jetta injectors and a LPFP on.
I am going to find the parts and specs of the OEM injectors and LPFP.
The reason I am looking for help is:
Does anyone have knowledge of a Passat B8 injectors, what cc they are?
Anyone know if the LPFP the same as the golf? What alternatives would anyone suggest - a TTRS?
Im also looking at the Bosch 980cc injectors as a staring point. But would rather find out what my current ones are.
Any help gratefully received.
If any Admins thing i should post this anywhere else on the forum, please let em know
Cheers in advance
You could try reaching out to HPA in Germany. Ask them what they did and if they have a solution. They build a 520HP Arteon and a wagon as well.
It also wouldn't surprise me if the LPFP is a little different in the Passat given that the fuel line is longer and the tank setup is different. Or... perhaps it's the same and the way the tank/lines might be your issue.
MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
