Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
Thread: Lowering Springs with DCC
  1. #31
    Mar 2017
    Tasmania
    Quote Originally Posted by doc_777 View Post
    Thanks mate - will get those numbers for all 4 corners and get back to you hopefully tonight. She has a sedan.
    Hey hey.
    turns out that both the front and rear are in the region of 395mm. Hope that helps.
    Mar 2018
    Hey hey.
    Hi Anthony,
    The catalogue listed Eibach Pro Kit will lower the sedan to approximately 350-355mm center of wheel to guard as per the picture attached. Is this stance appropriate ?
    Lowering Springs with DCC-b8-passat-pro-kit-2-jpg
    MY18 132TSI Comfortline Passat Wagon, Pyrite Silver
    Modifications : Legal Tint ,Rear Eibach Springs, Front + Rear Koni FSD Dampers
  3. #33
    Mar 2017
    Tasmania
    Quote Originally Posted by Pass2093 View Post
    Hi Anthony,
    yep, cheers that is good info - that the off-the-shelf kit will result in that stance. I think what visually makes that particular vehicle appear lower is the larger diameter wheels and tyres - makes it ‘look’ lower than it possibly is.
    Mar 2018
    Quote Originally Posted by lenny View Post
    what about sway bar (rear,.?) and is there part # and how to buy.? $
    Hi Lenny,
    Turns out the rear sway bar is ex-production due from completion in mid December.
    The earliest I can organise to have here is by mid to lat March with our stock orders.
    Pricing I expect to be around $428
  5. #35
    Mar 2017
    Tasmania
    Could I order the springs through a local Tassie outlet? Should I specify a kit or part numbers? Or if I buy through the ‘eibachdirect.com.au’ site, does that come though your company?
    what;s your first name anyway - be nice to addresss you by name
    I really appreciate you you help and advice - you have been great to members of this forum, openly helping with your knowledge.
    Mar 2018
    Hi Anthony,
    I have just sent you a PM as I don't want to disturb the forum rules.
    John
  7. #37
    Feb 2018
    Lenny, I noticed you mentioned your vehicle is 206R , is it a sedan or wagon ?
    Anyways the front ride height achieved after installation will come to approximately 350-355mm. However if this is too low there may be other non listed options that we can look at. Attached is a photo of sedan that will provide a good idea on front ride height.
    Attachment 39548
    Whats the ride quality like?
  8. #38
    Apr 2019
    Argentina
    help lowering Passat B8
    Hi, I have a Passat B8 2.0TSI with DCC. I want to lowering the car, 20mm/20mm front/back. The Eibach team recommended me Product code:
    E10-85-041-04-22. What do you think about it? Will be too lower? And with DCC, could it be ok? Thanks
    I use R17 for track day... all days wheels are R18
    Lowering Springs with DCC-passat_track-png
  9. #39
    Jul 2010
    Finally the Eibach Pro-kit (E10-85-042-02-22) is in!! woOot ��
    Its less wallowy (boat like) now in Normal mode. It's good now.
    Sport mode is nice n firm. Comfort mode is still comfortable ��
    I have DCC shocks.
    Lane Assist, ACC, TJA, etc. etc. all seem well and still behaving as before. Xenons need a slight lift.
    but otherwise all good.
    Before - 690mm from wheelarch to ground (front & rear)
    After - 670mm from wheelarch to ground (front & rear)
    or if measuring from wheelarch to centre wheel cap - 350/340mm (front/rear)
    Should drop another 5mm or so in the next few weeks.
    I'm very happy with it.
    Not too much.
    Not too little.
    Top half of each pic is After.
    Bottom half is Before.
    Lowering Springs with DCC-eibach-compare-01-jpg
    Lowering Springs with DCC-eibach-compare-02-jpg
    Lowering Springs with DCC-eibach-compare-03-jpg
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  10. #40
    May 2007
    Very Nice. Looks the Goods...
