Bear in mind that the 'Soft' setting will bring on sea-sickness a lot sooner than it normally does, as lowering springs are typically firmer. The 'Soft' setting in most cases with DCC has a bit of trouble controlling the oscillations of the standard springs as it is, in my experience.
You'll probably find yourself running it on the 'Hard' setting for the most part, as it could well ride like it's got blown shocks.
The springs will physically fit, as the only key difference with DCC shocks externally, is an electrical connector to control the internal valving.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
