Hi
I have 2017 passat r-line 132 tsi. For someone who used to drive gti, I would suggest you to go for passat 206.
I am totally happy with my car...all option including except bird view camera.
Today got cluctch replacement under good will and now is so smooth that is incredible. I didn't have problem except some shuddering when going from 1 to 2 nd geat and that was very internment.
I have sedan but boot, inside space is enormous. My previous car was Passat wagon and that car had ever bigger boot but less technical gadgets.
132TSI uses a dry clutch which will need to be replaced often (every 20k-40k) unless you get the 206TSI with the wet clutch
Dry transmission doesn't require any service. Dry transmission got chain as well so no need replacement.
Only wet transmission require oil change every 60K. Wet transmission using timing belt as well. Changes every 105K and costly.
206TSI using 7 speed dry transmission as well. I believe, wet transmission are reserved for diesel cars. If I am wrong, please correct me.
2. The Sunroof options consistently have rattling and quality issues
I have it, never had any problem with it..
_---------
3. Traffic Jam Assist is normally disabled and you'll need to get ODIS to have it enabled but this is possible.
No need. So many options already enabled
4. .... What else should I know or look out for or specific models and packages to opt for ? ie. luxury pack or r line?
When i got my rline, sunroof, digital display, auto leveling headlight are part of luxury pack as well.
360 sensors, auto parking etc could be part as well..
If you can get r-line including luxury pack you will be very happy
Sent from my SM-G986B using Tapatalk
2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
