SAFELOCK is a dead-locking system, it is not keyless entry. Basically, SAFELOCK disables the internal door handles once the car is locked.
Hi,
Purchased used car and interesting thing is that from the factory only Keyless-GO is installed to the vehicle. No keyless entry.
"Central locking system Keyless Go without SAFELOCK" from the equipment list.
Has anybody installed keyless entry to the car? Can give some hints how much the car must be taken apart to install all original parts of kessy system.
New exterior door handles with the kessy support must be changed. What components else needs to be changed or additionally added?
VCDS scan from control unit:
Address 05: Acc/Start Auth. (J51Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 HW: 3Q0 959 435
Component: VWKESSYMQB 023 0522
Revision: 00023000 Serial number: 0357395218
Coding: 000F0F0703
Shop #: WSC 05311 115 00317
ASAM Dataset: EV_KessyHellaMQBAB 004027
ROD: EV_KessyHellaMQBAB_004_VW37.rod
VCID: 77F6225BCE2EE6FEBB-8022
Thanks in advance!
Ainer
MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
2 (for front and rear doors) inner and 1 (for rear lid) outer aerials detects the key i assume.
I think that every door handle has own antenna for detecting the key, but not sure.
2015 Volkswagen Passat/4Motion/Santana Europe market: Electrics Control unit for access and
start authorisation
