As I am a bit of a gumby when it comes to things mechanical I wanted to find out if anyone has removal and installation instructions for a fog light trim for my 2017 Passat B8 206TSI R Line wagon.
The trim around the fog light on the left side has been damaged. I have already received the replacement trim but would prefer not to proceed without the instructions. In the end this will save me the pain of damaging more stuff. Thank you.
Hey mate, assuming it is the pastic around the foglight, there are instructions in the manual. Go to the "changing lamps" section and you should find it there. You use the tyre plastic cap remover to pull it out. Hope it helps ya!
