Its yet another silly useless invention, supposedly to make the coolant last longer, yet somehow designed to fail prematurely due to the fact they are inside a plastic mesh bag which splits open and allows the silica to spread all through your coolant system, making a horrible mess in the process.
I had the same thing happen to my Audi a few years ago - I do regular checks under the bonnet to check oil/coolant etc and all of a sudden I notice my coolant is this horrible brown rust colour. At this time I was not even aware of the silica bags inside the overflow tank - so I had no idea what had happened. What an annoying mess to clean all that brown coolant out as it stains everything. I flushed my cooling system about 10-12 times over the space of a few weeks with distilled water and various radiator cleaners like this RADIATOR FLUSH | Penrite Oil , driving around for several days with just water (or water plus cleaner) in the cooling system, before draining it and refilling again. In the end I finally got the system clean, but the overflow tank was horribly stained, so I bought a new overflow tank to satisfy my OCD. Unfortunately the new overflow tank also has a silica bag in it (which cannot be accessed to remove it), so the coolant tank will be something to periodically repace as preventative maintenance every 4-5 years. They are cheap enough so no biggie now that I know about it.
