Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Fuse box location for B8 Passat
  1. #21
    Oct 2016
    [QUOTE=SciroccoJ;1209759]Will do a write up in my blog soon! I am quite happy with the finally result!
    Hi SciroccoJ, when you get a write up, can you list the fuse numbers you used for battery and ACC. I'm going to attempt a hardwire install of a Thinkware F770 shortly, it would would save me time trying to figure out which fuses are best to use (going to use a couple of fuse holders). thanks
  2. #22
    Pacific Paradise QLD
    [QUOTE=Davids;1211964]
    Quote Originally Posted by SciroccoJ View Post
    Just be aware that depending on options installed, fuse boxes may not be identical. Mine was quite different to setout of standard one
  3. #23
    Oct 2016
    [QUOTE=Hillbilly;1211970]
    Quote Originally Posted by Davids View Post
    thanks for the heads up Hillbilly, I'll keep this in mind when I install.
    MY17 Passat 206TSI R-Line sedan, white, panoramic roof.
  4. #24
    Jul 2013
    Hi Dave,
    Been busy with work lately (still in office as I type this), will do the write up in the next couple of days.
    just FYI, I have tapped my Constant power to the trailer assist fuse and ACC to the cigarette lighter fuse.
    Regards
    Jacky
    MY13.5 Rising Blue Scirocco R - DSG - Sunroof - sold!
    MY15 Pearl Black Tiguan 155 R-Line - DSG - Dual Sunroof - SatNav - Leather - sold!
    MY17 Indium Grey Passat 206TSI R-Line Wagon - DSG - Dual Sunroof ... the Journey Continues ...
    Check out my blog for car photos and product reviews! http://www.infiniticious.com
  5. #25
    Oct 2016
    [QUOTE=SciroccoJ;1212180]
    Hi Dave,
    Regards
    Jacky
    thanks, much appreciated!
  6. #26
    Finally got around to install the dashcam today!
    The fusebox is actually located behind the glove box ... and it is stated in the owners' manual...
    No much trouble for the installation and I have managed to get the rear cam on to the hatch window! Only downside is I have snapped one of the metal trim clip ...
    Can anyone tell me where I can find a suitable grounding point close to the fusebox on a 2016 RHD Passat? No problem running the dashcam cable to the fusebox behind the glove compartment but I cannot find a single bolt there going into grounded metal - everything is plastic. I spent hours trying to find a grounding point in the area so I would appreciate it if anyone has found a solution. I'm wondering if there might be a suitable bolt under the side panel ( left hand end of the dash ) but I'm not sure how to remove that cover.
  7. #27
  8. #28
    Oct 2016
    Pop the left hand end dash panel off with a plastic trim tool (plastic kids knife worked a treat for me). The cover has 3 push in clips (top middle and bottom) so needs a bit of force. Once that's off there are a few bolts under the dash/on the door frame that will work nicely for the earth.
  9. #29
    Jan 2013
    Brisbane, QLD.
    The crash bar is also a very good ground point... and it's everywhere.
  10. #30
    Thanks guys! I will have a go when I next get some time. Was just a bit worried about trying to remove the end panel.
