Great, so wife tells me an error has come up on the passat alltrack. So i get home and check it out.
Fault: Vehicle Lighting.
Thinking it is just a bulb, start turning lights on/off. So i find that it looks like a major failure somewhere as the following don't work. Called Camberwell VW Service and am dropping car off monday morning for them to have a look at.
FR: Headlight & indicator not working
FL: DRL not working
RR: rightmost brake light not working
RL: indicator & border led not working
anyone else experience something like this?
2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
2023 MY23 Nevada White Cupra Formentor VZx
2015 Carnival Yellow Honda S660
Smells like a BCM issue
Check the fuses, circuits are often designed with diagonal lights on same circuit.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
BCM issue?
I did my codings back in april, a month after i picked up the car. So it has been working fine since then. If VW want to play hardball, then i will ask them to prove that my codings would cause a hardware failure like this. On a side note, does the car keep a log of coding changes?
