You have only done half of it Look in the Tiguan MK2 forum for full instructions
The full and correct instructions were only 2 posts above your moved one and it definitely works
Has your vehicle got the correct headlights to do it
Hi,
I tried to enable DLA but now getting the following error:
Tuesday,08,September,2020,19:29:28:34260
VCDS Version: Release 20.4.2 (x64) Running on Windows 8.1 x64
Ross-Tech: Home
Address 4B: Multifunc. Module Labels: 3Q0-907-338-V2.clb
Control Module Part Number: 3Q0 907 338 C HW: 3Q0 907 338 C
Component and/or Version: FCM MQB Low 002 0345
Software Coding: 000000060900034E03104F0502000004000000000000000000 0000000000
Work Shop Code: WSC 05311 123 08193
ASAM Dataset: EV_MultiModulContiVW48X 002006 (VW4
ROD: EV_MultiModulContiVW48X_002_VW41.rod
VCID: 3537202735C92BE3B15-8060
2 Faults Found:
5276145 - Power Output Module for Left Headlamp
C1081 F1 [137] - Incorrectly Coded
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 126
Mileage: 111 km
Date: 2020.09.08
Time: 19:27:10
5276401 - Power Output Module for Right Headlamp
C1082 F1 [137] - Incorrectly Coded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 126
Mileage: 111 km
Date: 2020.09.08
Time: 19:27:10
I followed the following steps:
Module 09 - Central Electrics
1. Connect OBD Eleven to your car.
2. Turn the ignition on, not the engine! These changes won't apply if the engine is on. I've tried it.
3. Go to central electrics module 09.
4. Select adaptions from the list.
5. Find "Fernlicht_Assistent" and go into that menu.
6. Change "Erweiterte Fernlichtsteuerung" to AFS FLA Fernlicht (GLW:MDF).
7. Change "Menusteuerung Fernlichtassistent" to present.
8. Change "Menusteuerung Fernlichtassistent Worksteinstellung" to present.
Module A5 - Front Sensor
1. Got to module A5 - Front Sensor.
2. From the list select "long coding".
3. Find byte 19 - Bit 0-3 Value 00
4. Find byte 19 - Bit 4-7 Value 30
5. Find byte 21. Change it to hex value 40.
Module 4B - Multifunction Module
1. Go to module 4B.
2. In the list, select long coding.
3. Go to byte 9. Change the hex value to 10.
4. Go into byte 10. Tap the checkbox on bit 6 to enable it. Make sure bit 5 is unticked.
5. Go to byte 11. Tap the checkbox on bit 2 to enable it.
I can see only "Dynamic Light Assist" in the radio light settings; "Dynamic Cornering" no longer exists. Is this how its supposed to be?
Please help.
I checked the coding again and its exactly as per the "Tiguan" post. However, I went back to module 4B, byte-9 and changed it back to 00 (Headlight type: Variant-1). With this setting, I can see "Dynamic light assist" and "Adaptive Front Lighting System" I need to get "Dynamic Cornering System" instead of "AFS"
I guess because mine is a Passat, the module settings may be different.
With the new settings, the previous two errors have gone and a new error has come:
Tuesday,08,September,2020,22:37:53:34260
Ross-Tech: Home
Address 4B: Multifunc. Module Labels: 3Q0-907-338-V2.CLB
Software Coding: 000000060900034E01004F0502000004000000000000000000 0000000000
VCID: 3537202734492BE3B15-8060
1 Fault Found:
0032 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 126
Mileage: 111 km
Date: 2020.09.08
Time: 22:33:35
Any thoughts? How can I get "Dynamic Cornering" instead of "AFS" in the radio lights menu?
Wow.. nobody?
I would also like to know how to perform the basic settings using VCDS. The instructions are for OBDII.
Settings will be the same how you get there is slightly different
Hi,
I have coded the modules correctly.
1. I can see Dynamic Light Assist and Adaptive Front Lighting system in the radio, lights menu - is this correct?
2. Changing the stalk to high beam shows the blue high beam icon but not the icon with "A"
3. My basic setting window is as shown below, with the menu. Which should I select? I did select Headlight Adjustment Start 1 and clicked go but nothing happened, hence my doubt on the basic setting.
Please find the screenshot as below.
Push it further then as you have to push it past the highbeam setting
I have NO IDEA about VCDS disnt see the pint in paying $450 for something that a $130 unit does far easier
Where is the RADIO LIGHTS menu
