Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Dynamic Light Assist (DLA) Coding Issues
    May 2019
    Perth, WA
    Where is the RADIO LIGHTS menu
    The radio menu is posted in #4
    There is no where to push further, this is what I get when I push "go"
    Dynamic Light Assist (DLA) Coding Issues-capture-jpg
    Pacific Paradise QLD
    Oh so the menu is in the MMI Radios went out last century
    Its in MMI/settings /Vehicle/Lights
    Yours lacks Dynamic cornering in the menu
    Lights menu
    Push your headlight stalk further forward and you should get a blue light with an A superimposed over it
    Attached Thumbnails Attached Thumbnails Dynamic Light Assist (DLA) Coding Issues-20200909_202229[1]-jpg   Dynamic Light Assist (DLA) Coding Issues-20200909_202246[1]-jpg
    May 2019
    Perth, WA
    Hi Hillbilly,
    Yay! It worked. The errors seemed to be due to a different issue. I was doing the coding last night and I ended up getting a battery low warning. I decided to go for a drive today evening and there was a warning in the cluster. I drove about 25 kms and suddenly noticed the warning disappeared! I then pulled the stalk and got the light assist icon in the cluster (headlight symbol with A superimposed in white colour. When driving in a dark or minimally illuminated roads, this turns blue. Both the low & high beams seems to move accordingly.
    The MMI/settings /Vehicle/Lights shows Dynamic Light Assist and Adaptive Front Lighting System though.
    One point to note: I had set module 4B, Byte 9, Bit 4-7 as 00 Head Light Type: Variant 1
    The Adaptive front lighting System disappears from the mmi/lights menu if I set it to 10 Head Light Type: Variant 2
    Not sure why.
    When your car turns on with the lights on AUTO they should dance like this
    https://drive.google.com/file/d/1-ST...ew?usp=sharing
    You need to do headlight adjustment Start 1
    and then
    Headlight adjustment 2 stop
    Done
