Page 21 of 26 FirstFirst ... 111920212223 ... LastLast
Results 201 to 210 of 257
Thread: Dynamic Light Assist
  1. #201
    Apr 2017
    Quote Originally Posted by phonebooth View Post
    Mine doesn't chime but has a visual alert in the AID just after I start driving.
    The chime is off then.
  2. #202
    Feb 2019
    Perth, WA
    Quote Originally Posted by zzc2010 View Post
    What makes you say that? Hillbilly has the same. My chime works for everything else; seat belts, doors, gear, ignition etc.
    MY19.5 Tiguan Highline with R-Line & Sound/Vision
  3. #203
    Apr 2017
    So you two’s working or not?
    Is it in fusion sign detect?
    Errors when drive off little bit or start up?
  4. #204
    Pacific Paradise QLD
    You can turn off the alarm in your settings.
    The car should decrease the speed from 80 to 40 if yours is working when using ACC.
    Yours probably is not.
    It s the overspeed alarm for whats on the roadsign and Ive reset it to much higher so I dont get it as much but having to have it 50 over is a bit much
    Mine had to change from Road sign Fusion to just Road sign detection to make it work in A5 Adaptation /Road sign detection Fusion Mode
  5. #205
    Feb 2019
    Perth, WA
    My TSR works fine. It just doesn't chime when I drive away, only a visual alert. It's in "Road Sign Detection" not Fusion.
  6. #206
    Apr 2017
    Then we are on the same page man.
    Only a working fusion TSR is fine.
    We are keen on getting TSR to work in fusion.
  7. #207
    Apr 2017
    Same page.
    I’m talking about a working fusion TSR.
  8. #208
    Same page.
    You are talking confusion. What do you actually mean TSR with GPS as well as camera.
  9. #209
    Just been up the road a little way where there are several different speed zones Heres what happened.
    Took off No speed signs Car showed 60 (correct) But!!! no sign
    Left shops showed 60 still correct Turned corner onto main road NO SIGN Changed to 70 as I turned.
    200m around sweeping corner is the 80 sign stayed at 80 and popped up the "TSR is working in restricted mode" NO SOUND
    Turn into off ramp changed to 70 NO SIGN Get to the 80 sign and it changes up.
    Shortly after is the 60 sign which it changes to correctly.. It didnt pick up the 100 sign on the left of the right hand road going to the motorway
    WTF is going on as it changes to speeds that arent there without a sign anywhere
    GPS has historic speed areas still in it?????????. A bloody mystery as it has done the same on the highway at roadworks where it has changed to speeds not shown and no signs to indicate speed anywhere in vision
    Heres where I travelled from bottom left to Coles then up to intersection at top centre then left across
    and down slip road back to bottom left
    Google Maps
  10. #210
    Feb 2013
    Perth, WA
    Google Maps
    The Fusion part means that it's fusion between GPS data and Camera Data. The Camera data is fine but the additional meta data is missing in the maps data for the speed, despite showing it in your main GPS screen. Unless they put the right information in the mapping data for AUS (I highly doubt it) then you're not going to get fusion working without it complaining. *EDIT* I think it has the right data in maps for highways/motorways, just not streets.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
