Page 20 of 26 FirstFirst ... 101819202122 ... LastLast
Results 191 to 200 of 258
Thread: Dynamic Light Assist
  1. #191
    Pacific Paradise QLD
    Quote Originally Posted by dArK5HaD0w View Post
    Certainly not enabled in the Superb - standard AFS, or SLA.
    As Kamold said, I think it requires the TSR in Fusion mode with the maps.
    While PACC would b nice to have, I don't want my car determining the speed I take a corner
    Might be the Arteon then but as the Traffic sign recognition is a bit flaky I agree with you.
    The other day coming through the roadworks on the Bruce north of Caloundra the icon changed speeds a couple of times when the signs gave a constant 80. At one point was 40 showing, which makes me wonder if the GPS has something to do with it
  2. #192
    Jul 2010
    my TSR is setup to only read speed signs detected by the camera. i.e. not fusion mode.
    so the only speed signs it shows on the infotainment or centre cluster r the ones it sees on the road.
    Fusion mode uses both GPS map data and the camera.
    the RoW map data does not seem to have the necessary data for fusion mode to work properly. at least is the case with the Columbus infotainment unit in Skoda.
    hence my TSR is coded/set to "Road Sign Detection" mode.
    However, given the Arteon uses the same RoW maps, and they have no issues - maybe the required data does exist in it. I may need to play around elsewhere with the "predictive" settings, that will then make Fusion mode happy. don't know.
    Truth b told, i reckon this is a SwaP-controlled feature, controlled by VAG, requiring an activation code for a particular car.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  3. #193
    Apr 2017
    Arteons still has a ding and error when startup after activating the TSR.
    I remember I saw it in the CC forum.
  4. #194
    Quote Originally Posted by zzc2010 View Post
    MY Tiguan doesnt beep or anything at all with TSR
  5. #195
    Nov 2016
    MAPLETON Qld
    Mine picks up any speed signs it sees, slip road exit speed signs, etc.
  6. #196
    Apr 2017
    Probably they fixed it on the later models then.
    What’s your firmware version of A5 module?
  7. #197
    Quote Originally Posted by Hole46 View Post
    So does mine its the ones that ARENT there that are a bother, as in cruising through 80k roadworks and all of a sudden it says 40k and alarm goes off
  8. #198
    Hardware version H09
    Software number 3Q0980654A
    Software version 072
    serial 31071812k12020
  9. #199
    Feb 2019
    Perth, WA
    Mine doesn't chime but has a visual alert in the AID just after I start driving.
    MY19.5 Tiguan Highline with R-Line & Sound/Vision
  10. #200
    Apr 2017
    You can turn off the alarm in your settings.
    The car should decrease the speed from 80 to 40 if yours is working when using ACC.
    Yours probably is not.
