MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
Hi Wynnston,
I'm Perth based with this working in my car (Tig). Fully activated with startup dance included. I activated it via OBD Eleven (no parameters required).
I'm happy to loan you my OBD Eleven if you want to have a crack? Should work on the newer Tiguans but if you have a Passat probably not much use to you.
MY19.5 Tiguan Highline with R-Line & Sound/Vision
Got it done thank you Seems to be doing the right sequence when lights do the dance so will see what happens in the dark tonight
Cleared all the errors as per instructions but when I did a full scan afterwards got 5 faults in control modules They came good after clearing them and they were Light control front left and right, one in 4B, one in A5 and one in 09 but all good now. Cornering lights are working when i turn the wheel in the dark in the garage
Light pattern Light pattern.mp4 - Google Drive
I noticed in the module for lights there is a setting for PREDICTIVE LIGHTS I wonder if thats what the Superbs have got and what would happen if it was enabled?????
wonder if it would need coding or just turning on
PACC predictive ACC is the next level again.
Available on Arteon (have seen it enabled on other cars but a lot of work) it fuses map data with camera and radar to bend lights before an upcoming bend, adjust speed before corners and adjust speed based on road sign recognition...
Sounds like it might be a bit overpowering if it does all that and the speed sign recognition isnt exactly perfect here as i have seen it put some odd speeds up when in fact they werent anywhere to be seen which makes me think that some of it is done from GPS location.
Have also seen that it apparently gave some drivers motion sickness as it was somewhat disconcerting to see the lights drift sideways and the car wasnt.
Can you remember the coding for the autoretracting drivers seat in a Passat??? I think you told me once about the time of the folding mirrors
