Originally Posted by
phonebooth
Ok, tonight we have a complete success. I've managed to get it all activated with no errors!!
2019 Tiguan SWB Highline with Sound & Vision and R-Line packs.
All steps completed with OBD Eleven Pro
My 4B coding below, note I already had HBA activated. That includes Central Electrics 09 Byte 2 bits 0 & 1 enabled. Not sure if that would make a difference or not.
Follow the initial linked instructions until you get to module 4B.
My module 4B value: 000000050900084E07104F050A000000000000000000000000 0000000000
Run basic headlight settings then acknowledge, clear the headlight basic setting fault in 4B - noticed the DLA headlight dance at this point.
After that, I went into the Discover Pro, Menu > Vehicle > Factory Defaults > Lights. Then I soft reset the MIB. Turned the ignition off, turned it back on, started the engine, all working.
Something to note is the cornering lights, despite not showing an error, didn't work until I did the above steps.
I'll get out on the road tonight and give it a whirl.
Hey, I know this is on a Tig but I managed to get it working on the Passat too. The downside is that we all think it still required further programming to work properly, not just module parameter changes, but actual programming.
I could get it to do all the stuff, except it wouldn't do the DLA style dance at start-up, just the normal one. It was also a bit slow to react to oncoming cars and cars from behind. It did it, but it was slow. I came to the conclusion that it wasn't quite working as it should and reverted it as I didn't want to blind someone in traffic. I understand from previous posts that the Tigs and some newer cars might already have this programming present, if it doesn't then you might want to look into getting it put in place before using it.
Happy to share my findings in detail over a PM, otherwise, I too am in Perth and have VCDS if you want to try some different things.
MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
