Originally Posted by
kamold
Were you able to apply all the coding and adaptations per the link you posted?
If so then you need to run basic settings on address 55 headlight range, and then run acknowledge basic settings.
I haven't done this with obd11 so you'll have to check if these two are available. They are 2 seperate routines. Both need to be run to success (a few seconds each only)
So, I don't have the startup sequence of the DLA system but can confirm it is working because it manages the beam when oncoming traffic approaches instead of just turning off like HBA. I'd love to work it out to get the DLA presentation working because it looks so much cooler.
There are two sets of instructions on that page. I followed the instructions for => 2017 models, but I did not have 4B so I followed the instructions on coding the 55 module from the < 2017 version, I didn't have Byte 4 bit 6 as a tickbox so I manually modified the code (byte 4 is now 4F Added a 1 to position 2 in the binary (is bit 6), I then also ran basic settings and then the apply basic settings. I had "Light Assist" errors come up in the MFD before that, now no errors.
DR074 probably has his working just like mine and we may have confused eachother because the startup sequence didn't change.
MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
