Page 26 of 26 FirstFirst ... 16242526
Results 251 to 257 of 257
Thread: Dynamic Light Assist
  1. #251
    Nov 2023
    Germany
    Hello guys,
    i want to upgrade my Bi-Xenon to Xenon with SLA on my Skoda Superb 3v
    I have a 4B unit 3q0907338c build in the car.
    I need to load new parameter via VCP.
    I can not find the corret Dataset file at VCP Filemanager.
    Could anybody help me?
    regards
  2. #252
    Mornington Peninsula, VIC
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
  3. #253
    Oct 2024
    Newcastle, NSW
    Have just completed all 26 pages of this upon recent purchase of a June 2017 build b8 Passat with LEDs.
    Has anyone come to the conclusion from usage that the DLA is not a valid function or was it just that the parameters were wrong?
    Do you require VCP or can you use VCDS. It appears some of the links are broken and no longer work.
  4. #254
    Quote Originally Posted by Nusai250 View Post
    Yes it needs correct parameters as well as coding and adaptations
    Sent from my SM-S921B using Tapatalk
  5. #255
    Aug 2021
    It's definitely a valid function - @Kamold set DLA up perfectly in my MY18 Passat along with various other tweaks and goodies.
  6. #256
    Oct 2024
    Newcastle, NSW
    Thanks for the update Kamold and Petemac110. Have just picked up a B8 2017 TDI Passat with high LED's but unfortunately the left headlight's low and high beam are not working and after replacing the power module (7PP.941.572.AB) the outside light beamisn't working so picked up a headlight complete for $1,000 AUD. (still throwing error codes 'U117000' and 'C108131' with message "LED headlamp power output stage".
    After I have get this working, I'll use my VCDS and follow the instructions onActivate Dynamic Light Assist (DLA) - from MY 2017 - AS.Coding (ascoding.ch) and see how we go.
    I know it's been mentioned here and elsewhere but it is wild to know that Volkswagen put the capabilities in the hardware and software but didn't include it with these cars. I do wonder how much it would have cost from factory to option in 'DLA'.
  7. #257
    Jan 2025
    Hungary
    Hello all!
    I have a Passat B8 MY15. I tried to activating the DLA with VCDS following these instructions:
    Activate Dynamic Light Assist (DLA) - up to MY 2017 - AS.Coding
    After the coding, adaptation, basic settings, soft resetting the Discover Pro main unit, I have a strange problem.
    I DON'T HAVE HIGH BEAMS NEVER.
    In the "Car--> Setup --> Light settings menu" I can select the "Light Assist" (not Dynamic Light Assist).
    When the light switch is in Auto position and I push the lever towards front, I got a "Light Assist Fault" message. If I coding in module A5 byte 21, bit 5-7 to "20 Light Assist (AFS) - High Beam Assist (HBA)" and push the lever towards front there are no fault message and the "A" symbol is turning on at the instrument cluster.
    With this settings above, when I drive at night above 60 km/h and nobody come in front of me, the blue high beam icon turned on, when someone come it turns off, when passed turns on again. But the HIGH BEAM never turned on exactly from the headlamps.
    If I try to turn on manually by pushing or pulling the lever, it only turns on the blue high beam icon on the instrument cluster, but the light is remain on main beam.
    When the light switch is on "0" positon and I pull the lever to activate the high beam light horn it only light the main beam.
    I hope it is understandable as I wrote.
    Anyone could some help in this "no high beam" problem?
    I have auto scan file, just dont know how to upload here.
    Thank you in advance.
