Page 9 of 26 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 256
Thread: Dynamic Light Assist
  1. #81
    Apr 2017
    Quote Originally Posted by mythik View Post
    What's curious is;
    Arteon - approach car in front - blacks out car in front / keeps high beam on
    Golf R - same as arteon
    Passat - can block out left and right individually, not centre. When above situation would occur system simply turns off back to low beam.
    The setting in the module that tells the car it has a roller highbeam compatible headlight is why. This is because there isn't a roller in the headlights in the Passat B8. ALTERNATIVELY. It needs some special coding / software. I'm not certain. It just doesn't enable as it should. See my code snippet above as to what should be visible in 4B Byte 3 for DLA roller headlights.
    Anyone have an autoscan from a DLA enabled Passat B8 from Germany to compare?
    Never know Golf R has DLA as well
    The only car in VW has DLA enabled from factory should be Arteon in Australia
    I could be wrong. Can’t remember.
  2. #82
    What's curious is;
    I wonder if the parameter set for the AFS module does more than just change the startup sequence perhaps?
  3. #83
    Apr 2017
    I feel so.
  4. #84
    Jan 2018
    Switzerland
    What's curious is;
    Hi
    There is an autoscan from a VW Aerton with factory-DLA:
    Fahrzeugtyp: 3H-VW48 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 42 44
    47 4B 52 5F 6C 6D 75 A5 A9 BB BC CA D6 D7
    Fahrzeug-Ident.-Nr.: WVWZZZ3HZHE702358 Kilometerstand: 305km
    01-Motorelektronik -- Status: i.O. 0000
    02-Getriebe -- Status: i.O. 0000
    03-Bremsenelektronik -- Status: i.O. 0000
    05-Zugangs-/Startber. -- Status: Fehler 0010
    08-Klima-/Heizungsel. -- Status: i.O. 0000
    09-Zentralelektrik -- Status: i.O. 0000
    10-Einparkhilfe 2 -- Status: i.O. 0000
    13-Distanzregelung -- Status: i.O. 0000
    14-Raddämpfung -- Status: i.O. 0000
    15-Airbag -- Status: i.O. 0000
    16-Lenkradelektronik -- Status: i.O. 0000
    17-Schalttafeleinsatz -- Status: i.O. 0000
    19-Diagnoseinterface -- Status: i.O. 0000
    22-Allrad -- Status: i.O. 0000
    29-Lichtsteuerung li. -- Status: i.O. 0000
    2B-Lenksäulenverrieg. -- Status: i.O. 0000
    36-Sitzverst. Fahr. -- Status: i.O. 0000
    39-Lichtsteuerung re. -- Status: i.O. 0000
    42-Türelektr. Fahrer -- Status: i.O. 0000
    44-Lenkhilfe -- Status: i.O. 0000
    47-Soundsystem -- Status: i.O. 0000
    4B-Multifunktionsstg. -- Status: i.O. 0000
    52-Türelektr. Beifahr. -- Status: i.O. 0000
    5F-Informationselek. I -- Status: i.O. 0000
    6C-Rückfahrkamera -- Status: i.O. 0000
    6D-Heckklappe -- Status: i.O. 0000
    75-Telematik -- Status: i.O. 0000
    A5-Front-/Vorfeldkamera -- Status: i.O. 0000
    A9-Körperschallaktuator -- Status: i.O. 0000
    BB-Türelektronik hinten links -- Status: i.O. 0000
    BC-Türelektronik hinten rechts -- Status: i.O. 0000
    CA-Schiebedachelektronik -- Status: i.O. 0000
    D6-Lichtsteuerung links 2 -- Status: i.O. 0000
    D7-Lichtsteuerung rechts 2 -- Status: i.O. 0000
    Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\5Q0-937-08X-V2.clb
    Teilenummer SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
    Bauteil: BCM PQ37BOSCH 034 0242
    Revision: -------- Seriennummer: 865821041700P1
    Betriebsnr.: WSC 00015 115 08193
    ASAM Datensatz: EV_BodyContrModul1UDSBosc 018001
    ROD: EV_BCMBOSCH_018.rod
    VCID: 065464E2A8A99D07616-8052
    Steuergerät für Wischermotor:
    Subsystem 1 - Teilenummer SW: 3G1 955 119 A HW: 3G1 955 119 Labeldatei: DRV\5QX-955-119-V1.CLB
    Bauteil: WWS 170401 042 0607
    Seriennummer: 170419161555
    Codierung: 0E4DDD
    Sensor für Regen- und Lichterkennung:
    Subsystem 2 - Teilenummer SW: 81A 955 547 A HW: 81A 955 547
    Bauteil: G397_RLFS H06 0002
    Seriennummer: 20227625X81A955547A0
    Codierung: 00006E
    Lichtschalter:
    Subsystem 3 - Teilenummer SW: 3G8 941 633 HW: 3G8 941 633
    Bauteil: E1 - LDS MQB H01 0032
    Seriennummer: 22 02 2017 10000613
    Geber für Luftfeuchtigkeit: innen:
    Kein(e) Fehlercode(s) gefunden.
    Adresse 10: Einparkhilfe 2 (J446) Labeldatei:| DRV\5Q0-919-294.clb
    Teilenummer SW: 5QA 919 294 B HW: 5QA 919 294
    Bauteil: PDC 8 KanalH07 0044
    Seriennummer: 000308418617095
    Codierung: 0471151811
    Betriebsnr.: WSC 05311 115 00073
    ASAM Datensatz: EV_EPHVA18AU3700000 009035
    ROD: EV_EPHVA18AU3700000.rod
    VCID: 4BC295D6F34BA06FFE8-801E
    Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5G0-920-XXX-17.clb
    Teilenummer SW: 3G0 920 791 C HW: 3G0 920 791 C
    Bauteil: KOMBI 405 3193
    Codierung: 07A4101BFF84000801806B031001000880000000
    Betriebsnr.: WSC 00015 115 00001
    ASAM Datensatz: EV_DashBoardVDDMQBAB 009058
    ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
    VCID: 290E0F5E5977927F2C4-807C
    Adresse 19: Diagnoseinterface (J533) Labeldatei:* Keine
    Teilenummer SW: 3Q0 907 530 C HW: 3Q0 907 530 C
    Bauteil: GW MQB High 515 5286
    Seriennummer: 23041710800233
    Codierung: 030300047F085900FB00827E9C0F0001000107000000000000 0000000000
    ASAM Datensatz: EV_GatewNF 013020
    ROD: EV_GatewNF_VW27.rod
    VCID: 2F3AE1466793FC4FF20-807A
    Generator:
    Steuergerät für Multifunktionslenkrad:
    Subsystem 2 - Teilenummer SW: 5G0 959 442 K HW: 5G0 959 442 K Labeldatei: DRV\3C8-959-537.CLB
    Bauteil: E221__MFL-DC1 H17 0040
    Seriennummer: 46170001122840117166
    Codierung: 2DFFFF
    Steuergerät für Batterieüberwachung:
    Subsystem 3 - Teilenummer SW: 5Q0 915 181 J HW: 5Q0 915 181 J
    Bauteil: J367-BDMConti H03 1050
    Seriennummer: 7588600000170420035C
    Analoguhr:
    Subsystem 4 - Teilenummer SW: 3G0 919 204 C HW: 3G0 919 204 C
    Bauteil: Analoguhr 209 2002
    Adresse 29: Lichtsteuerung li. (J101 Labeldatei: 8V0-907-399.clb
    Teilenummer SW: 8V0 907 399 B HW: 8V0 907 399 B
    Bauteil: LCM_MLBevoH08 0014
    ASAM Datensatz: EV_LCMLeftHELLAAU736 001012
    ROD: EV_LCMLeftHELLAAU736_VW48.rod
    VCID: 45D6A3EED52F561F28C-8010
    Adresse 39: Lichtsteuerung re. (J1023) Labeldatei: 8V0-907-399.clb
    ASAM Datensatz: EV_LCMRightHELLAAU736 001012
    Adresse 4B: Multifunktionsstg. (J745) Labeldatei:* Keine
    Teilenummer SW: 3Q0 907 338 HW: 3Q0 907 338
    Bauteil: FCM MQB Low 001 0285
    Seriennummer: 27041710802533
    Codierung: 000000050100045207106F0502000000000000000000000000 0000000000
    Betriebsnr.: WSC 05311 000 08193
    ASAM Datensatz: EV_MultiModulContiVW48X 001010
    ROD: EV_MultiModulContiVW48X_VW27.rod
    VCID: 72BC2832B42191A75DE-8026
    Adresse 5F: Informationselek. I (J794) Labeldatei:| 5G0-035-MIB-HGH2.clb
    Teilenummer SW: 5NA 035 022 HW: 5NA 035 022
    Bauteil: MU-H-LND-EU H51 1077
    Seriennummer: A846D0HB003010
    Codierung: 02840301000000005111010200880A101F010AE4012004009E
    ASAM Datensatz: EV_MUHig4CGen2HBAS 001001
    ROD: EV_MUHig4CGen2HBAS_VW37.rod
    VCID: 70B8223ABA2DA3B7ABA-8024
    Anzeige- und Bedienungseinheit 1 für Informationselektronik:
    Subsystem 1 - Teilenummer SW: 5G6 919 606 HW: 5G6 919 606
    Bauteil: ABT_High-2 H50 9120
    Seriennummer: VWZ6ZHT1290422
    Datenträger:
    Subsystem 2 - Teilenummer SW: V03 959 800 QQ HW: -----------
    Bauteil: ECE 2017 --- 0157
    Seriennummer: --------------------
    Compact Disc Datenbank:
    Subsystem 3 - Teilenummer SW: V03 959 800 EG HW: -----------
    Bauteil: Gracenote2 --- 1015
    Adresse A5: Front-/Vorfeldkamera (R242) Labeldatei:| DRV\3Q0-980-65X-A5.clb
    Teilenummer SW: 3Q0 980 654 J HW: 3Q0 980 654 A
    Bauteil: MQB_B_MFK H07 0273
    Seriennummer: 21041712P13099
    Codierung: 0004080400000401002223448150A90094000E300040
    ASAM Datensatz: EV_MFKBoschMQBB 001001
    ROD: EV_MFKBoschMQBB_VW36.rod
    VCID: 3E24CC02B0F905C7696-806A
    Adresse A9: Körperschallaktuator (J869) Labeldatei: Keine
    Teilenummer SW: 3G8 907 159 HW: 4H0 907 159 A
    Bauteil: SAS-GEN 2 H07 0003
    Seriennummer: 170407203707
    ASAM Datensatz: EV_SoundActuaGen2AU64X 003010
    ROD: EV_SoundActuaGen2AU64X_VW26.rod
    VCID: 71BE273EB127AABFA44-8024
    Adresse D6: Lichtsteuerung links 2 (A31) Labeldatei: 7PP-941-572.clb
    Teilenummer SW: 7PP 941 572 AB HW: 7PP 941 572 A
    Bauteil: LED1L H09 0003
    Betriebsnr.: WSC 00000 000 00000
    ASAM Datensatz: EV_LEDModLeftMELCOAU736 001004
    ROD: EV_LEDModLeftMELCOAU736_VW48.rod
    VCID: 167434A2F8092D87916-8042
    Adresse D7: Lichtsteuerung rechts 2 (A27) Labeldatei: 7PP-941-572.clb
    Bauteil: LED1R H09 0003
    ASAM Datensatz: EV_LEDModRightMELCOAU736 001004
    Ende--(Dauer: 02:44, Batt.-Spannung Start/Ende: 11.7V/11.8V. VIgn 11.9V)---
    Hope it helps you
    Regards
  5. #85
    Quote Originally Posted by murmeltier View Post
    Hi
    Hope it helps you
    Regards
    Thanks for that are you also able to get an adaptation channel map from the A5 camera module and 4b led controller?
  6. #86
    Jan 2018
    Switzerland
    Yeah of course. I uploaded everything to my website, because it wasn't possible to upload a *.csv file here...
    VW Aerton, MY2017 - VCDSSchweiz
    Hope it will help you. Until now I never had a MY2018 to code...
  7. #87
    Dec 2017
    QLD Australia
    Hi Guys
    There's also a rainy day mode with the Arteon which can be set to auto to change the light setting when it's raining. Only have OBD11 but if you need a download, just tell me how to do it, and happy to share as you all have helped immensely with your posts to get a bunch of stuff working on my Arty.
    Sent from my SM-G935F using Tapatalk
  8. #88
    Nov 2008
    Ocean Grove, Vic
    If this option is available in the Golf and Tiguan... why does the Passat miss out?
    _____________________________________
    MY09 Passat 125tdi Wagon, White, RNS510, Tint, Bluetooth
  9. #89
    Quote Originally Posted by jmj View Post
    If you read the thread you'll find it was first enabled on Passats
  10. #90
    Apr 2017
    I enabled Rain Mode once. Barely noticed the difference in the rain. Checked full speced EU Passat and they don’t enable this function. Thus, I kept it disabled.
    The thing is Passat has fog lights and all the Audi and Arteon don’t (all weather lights instead).
    Rain Mode and All Weather lights can be easily replaced by fog lights, can’t they?
    Same functions different looks.
    You can enable all modes and weather lights in the codings. You need to try and see if there are differences.
