Originally Posted by
DR074
Hi
Both Wynnston and I had to follow half of the Pre 17 and half of the Post 17 instructions. If your Headlights are in Control Unit 4B, use that part of the instruction. Our Headlights are in 55.
I think that Byte 02 - Bit 0 is the same as changing the below (I could be wrong, but has worked)
Control unit: 09 Central Electrics
Adaptations: Fernlicht_assistent: Erweiterte_Fernlichtsteuerung: AFS, FLA, Fernlicht (GLW,MDF)
Don't forget to do the below;
Once coding in Control Unit A5 and 55 (or 4B) is completed,
Clear errors
Run Basic Settings for headlights
Acknowledge Basic Settings
Clear errors
Soft reset in MIB2
Car > Settings > Factory Reset > Lights > Reset
Car needs to be in "Normal" Driving Mode for DLA to work as in the video.
Happy hunting
