Page 2 of 26 FirstFirst 123412 ... LastLast
Results 11 to 20 of 258
Thread: Dynamic Light Assist
    Quote Originally Posted by DR074 View Post
    Hi Wynnston,
    Activate Dynamic Light Assist (DLA) - up to MY 2017 - VCDSSchweiz
    The above worked on my 206, DLA is working on my car. Used OBD11
    Is your headlight range controller at address 55 or 4B?
    And what is the pn of your BCM?
    There seem to be 3 variations....
    My16 has address 55 and BCM which can be coded
    My17 has address 4b and BCM which has no coding, only adaptation channels.
    Then the last variant (which nobody seems to have encountered until now) has the older address 55 headlight controller and new adaptation only BCM.
    This last variant requires a parameter set upload to address 55 to activate AFS with MFD (masking).
    First 2 variants require coding and adaptation only.
    Last one needs coding, adaptation and a parameter set.
    Hopefully we can figure out by model and year how these break down in Australia.
    Sep 2017
    Hi
    The address for headlight is 55, not sure what the pn is. Still a noob at all this stuff.
    Does any of the below help?
    Backup
    Control unit: 55 Headlight Regulation
    System description: AFS-ECU
    Software number: 7P6907357C
    Software version: 0120
    Hardware number: 7P6907357B
    Hardware version: H01
    Serial number: --------------
    ODX name: EV_HeadlRegulAFSMQBMLB
    ODX version: 001001
    Backup name: 55
    Long coding:
    03A60300CF210200
    Subsystems:
    Subsystem: LeiMo links
    Long coding: E02400
    Subsystem: LeiMo rechts
    Long coding: E02400
    Subsystem: LED LeiMo li.
    Long coding: E02400
    Subsystem: LED LeiMo re.
    Long coding: E02400
    fingers crossed
    Mine - Mustang GT MY20 - Carbonised Grey - "Nicky"
    Hers - T-Roc 140 TSI Sport MY21 - Reveena Blue - "Rocky"
    Previous - Passat 206TSI MY17 - Night Blue
    Hi
    Backup
    ODX version: 001001
    Backup name: 55
    Long coding:
    03A60300CF210200
    Subsystems:
    Long coding: E02400
    Long coding: E02400
    Long coding: E02400
    Long coding: E02400
    fingers crossed
    Ok how about address 09 central electrics? (BCM)
    I'm guessing you followed the my16 coding ?
    Sep 2017
    Oops, I may have posted the wrong link. From memory, used the from 17.
    Activate Dynamic Light Assist (DLA) - from MY 2017 - VCDSSchweiz
    Below is the backup for 09. No coding, all adaptations. Needed google translate.
    Backup
    Control unit: 09 Central Electrics
    System description: BCM PQ37BOSCH
    Software number: 5Q0937086BH
    Software version: 0222
    Hardware number: 5Q0937086BH
    Hardware version: 032
    Serial number: 865811081601M1
    ODX name: EV_BodyContrModul1UDSBosc
    ODX version: 017002
    Backup name: 9
    Long coding:
    Took some fiddling from memory
    Feb 2013
    Perth, WA
    Hi Wynnston,
    So are yours on Main Beam all the time and then when a car is oncoming it only dims that portion, or does it turn Main Beam off all together?
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
    Sep 2017
    Just checked that second link, ah no. definitely pre 17.
    Sep 2017
    Sorry, yes its on all the time and it dims them from main beam when a car drives past or you come up on street lights.
    it just dims them from main beam.
    What does the startup sequence for the headlights look like?
    If it's DLA you see the lights sweep up and down then out and in with a definite mask visible in the middle.
    Regular AFS sees light all across the frontal area.
    Not sure if this makes sense...
    Here is a video of DLA startup in slomoTapatalk Cloud - Downlaoad File VID_1510282960396.mp4
    Sep 2017
    Yep, the start sequence does the dancing headlights. Sweep out, in, up and down.
    But can you see the masking in the middle?
    My 2009 car with AFS does the sweeps.
    But it cannot mask like that.
