Page 16 of 26 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 258
Thread: Dynamic Light Assist
  1. #151
    Jul 2010
    Quote Originally Posted by Hole46 View Post
    Sorry, just checked my OBD11 history, my 4B coding is
    000000050100085607104F010A000000000000000000000000 00000000000, must have missed a few numbers.
    Even if u sort out the long coding, it won't work unless u upload the correct 4B parameter file.
    Once u have the file, then u will either need VCP or ODIS to upload it.
    VCP couldn't do it for me, but ODIS was able to.
  2. #152
    Feb 2019
    Perth, WA
    No, no parameters uploaded, just used the instructions about five times with the usual “Light assist “ & AFS errors. Can be frustrating.
    I've just re-traced my steps offline in OBD Eleven and I still can't see where I'm going wrong. Very strange that it's possible in the 2017 Tiguan without any parameter sets but not in a 2019.
    I'll re-try again tonight in a live state. This might sound silly but I did the coding with the lights off (DRLs on). I assume that's correct/doesn't make a difference?
    EDIT
    Quote Originally Posted by dArK5HaD0w View Post
    Must've got this in as I was writing my reply. Might not bother re-trying tonight then!
  3. #153
    Jul 2010
    p.s. when u see "Dynamic Light Assist" option in the infotainment, it could mean either HBA (high beam assist) or DLA (dynamic light assist) is enabled.
    HBA does not require uploading of 4B parameter files.
    DLA does require uploading of 4B parameter files, unless it was pre-loaded from factory, which i believe the Arteons and the newer Golfs are.
    i don't know if the Tiguan fits in the same bucket too.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  4. #154
    Feb 2019
    Perth, WA
    I have HBA active at the moment (had it activated prior to attempting DLA) - that works perfectly and appears as "Light Assist" in the head unit. When I coded (or attempted to) DLA, it appeared as "Dynamic Light Assist"
  5. #155
    Nov 2016
    MAPLETON Qld
    Quote Originally Posted by phonebooth View Post
    EDIT
    With me, it was just persistence, if you managed to change the coding in 09 toAFS, FLA, Fernlicht (GLW,MDF), you shouldn’t need to change any parameters.
  6. #156
    Whilst it is entirely possible that the 4b multifunction controller has the DLA parameter set from factory, with it disabled just by coding, I find this unlikely.
    Even if it's coded correctly and not faulting, is it actually properly performing DLA functions as opposed to HBA?
    For one it won't have the correct startup sequence (side to side, down and up, then masking inside to out).
    It's very difficult to do but if possible could you show a video of DLA functionality?
  7. #157
    Nov 2016
    MAPLETON Qld
    It’s not HBA, I had that enabled previous to DLA, and the startup sequence is different, similar to what you mention.
  8. #158
    That's a bonus.
    When we enabled it in a B8 previously the startup sequence didn't change until the parameter set was loaded.
    So at some point in the production cycle they must have changed the configuration so that the 4B controllers so that they are pre-loaded with DLA parameter set.
  9. #159
    Jul 2010
    that is a bonus indeed - getting away without requiring the MDF parameter file to be uploaded.
    p.s. this is how the DLA looks like on start-up.....
    and in action......
  10. #160
    Dec 2010
    Helensburgh
    I really like the way it operates with one question. If you are following a car on a long straight, say 300/400 metres behind with no oncoming traffic will it shade that car from full high beam? Has anyone tried the experiment?
