Page 15 of 26 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 258
Thread: Dynamic Light Assist
  1. #141
    Feb 2013
    Perth, WA
    Maybe you could sell it on after using it, or form a consortium of other guys in your same situation (only need it for a single use) and send it on to them once you've used it?
    Good idea. "Kamold, the voice of logic and reason"
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
  2. #142
    Feb 2019
    Perth, WA
    So I had a crack at this tonight after building up what I thought was enough knowledge to attempt.
    2019 Tiguan Highline w/ R-Line + Sound and Vision pack. Correct headlight assembly for DLA.
    Following these instructions: Activate Dynamic Light Assist (DLA) - from MY 2017 - AS.Coding
    Module 09 - Central Electrics
    Erweiterte_Fernlichtsteuerung
    New value: AFS, FLA, Fernlicht (GLW,MDF)
    The other two requirements were already set to present due to HBA already being active.
    A5 Front Sensors Driver Assistance System
    New value: 000307060000010100022346C150A90098000E300040
    4B Multifunction Module
    New value: 000000050900084E07004F010A000000000000000000000000 0000000000
    I then hopped out the car, cleared the headlight fault, ran basic settings, acknowledged the basic settings & cleared the headlight fault again. It cleared and all seemed good.
    Jumped back in the car, saw that Dynamic Light Assist was ticked in the head unit. Pushed the high beam stalk forward and received "Light assist error"
    I tried to follow the next steps in the guide if you received a light assist error. I completed the coding but was unable clear the headlight fault and run basic settings. OBD Eleven kept saying that there were minor errors preventing it from running.
    Any help is appreciated.
  3. #143
    I am not sure it will work without a proper parameter set for the 4B multifunction module....this has been my experience with both Passat B8 and Superb 3 DLA.
  4. #144
    Nov 2016
    MAPLETON Qld
    Quote Originally Posted by phonebooth View Post
    The 4B module long coding on mine is
    000000050107104F010A0000000000000000000000000000
  5. #145
    Feb 2019
    Perth, WA
    Quote Originally Posted by Hole46 View Post
    That's very different to mine. What car do you have?
    By parameter set you mean the basic set of available functions programmed into the module from the factory? Sorry, newbie here.
  6. #146
    Jul 2010
    i also had the "Light Assist" fault after i retrofitted the SLA (DLA for Skoda).
    once the correct 4B parameter files was uploaded (via ODIS), thanks to @Kamold, it was all good.
    there r 3 types of parameter files for 4B:-
    1. Level Control Only
    2. AFS
    3. AFS with MDF
    Dynamic Light Assist-vcp-b8dla-jpg
    mine had the "AFS" parameter file from factory.
    we uploaded "AFS_with_MDF", and all was good after.
    on some cars, VCP can do it.
    Dynamic Light Assist-light-assist-fault-jpg
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  7. #147
    Nov 2016
    MAPLETON Qld
    2017 Tiguan R-Line 162
  8. #148
    Feb 2019
    Perth, WA
    This is probably spanning a bit beyond my capability. I don't think OBD Eleven is capable of uploading a parameter set, nor do I know how to do it.
    Hole46 - did you need to upload the parameter set dArK5HaD0w and kamold are referring to?
  9. #149
    Nov 2016
    MAPLETON Qld
    Sorry, just checked my OBD11 history, my 4B coding is
    000000050100085607104F010A000000000000000000000000 00000000000, must have missed a few numbers.
  10. #150
    Nov 2016
    MAPLETON Qld
    No, no parameters uploaded, just used the instructions about five times with the usual “Light assist “ & AFS errors. Can be frustrating.
