Results 11 to 20 of 24
Thread: Do you use auto hold ?
    Jun 2017
    Perth, WA
    I can't not use auto hold. I find it too much of a luxury now.
    Starting the engine after the auto stop has kicked in can be done with a slight tap of the accelerator. Slight enough will engage the engine and not release auto hold.
    Don't put your foot down as if you were going to take off, it's a 2 step process. Once you've got that covered there's no more jerky take offs.
    His: 2018 Golf 7.5 R Wolfsburg Edition Hatch
    Hers: 2017 Passat B8 206 R-Line Sportswagon
    Quote Originally Posted by el1x View Post
    I tried this today and it works pretty well. I like having that control over starting the engine and the takeoff is quite a lot smoother. I still find the auto hold holds on a bit too long so might try the VCDS change others have mentioned to do the early release. My only other complaint is auto hold coming on when reversing. I would prefer it was disabled when reversing. I have a steep driveway to reverse down and the the auto hold kicks in if i stop half way down. To move off i have to hit the accelerator which is not what i want to do when reversing down a steep slope. I guess i could turn auto hold off at that point but it makes the whole thing pretty complicated for what should be a simple task. Wondering if there is a VCDS change anyone knows which will disable auto hold when in reverse.
    Passat Alltrack MY16
    Dec 2010
    Helensburgh
    Try it several times and concentrate on what is happening.I think you are blaming the AH on what really is slow throttle response that all Tiguans have and a lot complain about. Put the car is sport and give it a go then compare that to normal driving mode.
    Jun 2017
    Perth, WA
    My MY15 Golf has a pretty aggressive auto hold and it took a bit of practice but I can reverse to the point of crawling without the auto hold kicking in.
    It's all in the amount of pressure on the brake and keeping it constant with a steady foot.
    Dec 2010
    Helensburgh
    There is no comparison between our Golf PP and the Tiguan in throttle response and the AH. The Golf feels like it has a switch attached to the throttle and the Tiguan feels like it takes a message and then thinks about moving. Funnily enough I find the Tiguan easier to get on with but they are both vehicles built to a market.
    Jun 2017
    Perth, WA
    Quote Originally Posted by Ozsko View Post
    I have an MY15 Golf & MY17 Passat 206 - can't comment on the Tiguan.
    Agreed there are differences, each with their own challenges but just take time to get used to.
    Feb 2013
    Perth, WA
    Ooh. Another 206 owner in Perth. Seeing more around now. Just spotted a light blue one in Busselton.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
    Nov 2019
    Ballarat
    Sounds intriguing (not sure I entirely get the purpose of it), is this something the MY20 Polo GTI (Australian market) has too?
    Thank-you.
    Apr 2018
    I never use auto hold or auto start or any other aids besides acc. If i am starting from a steep I may use left foot on brake so its a gentle take up on the clutch.
    I'm always respectful of the DSG and torque spikes when taking off with this car.
    Pacific Paradise QLD
    Quote Originally Posted by Just_Westy View Post
    By doing that it causes clutch slip which can eventually be detrimental.
