Results 1 to 10 of 15
Thread: Digital dashboard scratched.
    Was just cleaning my dash with a microfibre towel and scratched my digital dashboard at least 150mm from the centre of my speedo to my tacho. Just a heads up to everyone out there that your dashboard is easily scratched. I believe it was my fingernail that did a pretty good job of it without me even knowing as the amount of pressure applied when dusting off my dash was minimal.
    Secondly would anyone have a product or technique that may help disguise this hideous scratch?
    Thanks in advance.
    Apr 2017
    belgrave victoria
    Damn thats sucks hard my sympathy to you
    Makes me be extra careful with mine
    Glad its coated in pomponazzi should help scratch resistance
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Pacific Paradise QLD
    Toothpaste or the headlight reconditioning stuff you buy at Supercrap
    Quote Originally Posted by Kachingg View Post
    Thanks bud.
    Yeah it's super easy to scratch. My nails aren't even sharp or long and I didn't even feel it absolute minimal pressure be careful.
    Wow I may give it a try in a small area first.
    Thanks for the advice
    Apr 2017
    belgrave victoria
    Quote Originally Posted by Asahi1985 View Post
    Let us know how you go (in case i balls it up and scratch mine lol)
    good luck hope it works
    Aug 2011
    Mount Colah, New South Wales 2079
    I've used Meguiar's PlastX cleaner/polish formulated to remove light scratches/marks on clear plastics with great success on VW head & tail light lenses/covers, so should also work OK on internal clear plastic parts.
    It's stocked by most auto parts retailers such as SuperCheap, AutoBarn, Repco, etc, about $15.00 for approx 300ml bottle.
    Mar 2017
    Tasmania
    The dash screen is not smooth plastic - personally, I would be very reluctant to apply any kind of abrasive or polish as the surface is textured.
    I clean my dash with a dust removal cloth regularly - never had an issue with scratching. Although I have in the past left a mark that looked a lot LIKE a scratch - it buffed out easily with a microfibre cloth.
    Personally I would be taking a long hard look at it with magnifying equipment before going near it with any kind of abrasive etc.
    Feb 2013
    Perth, WA
    I usually get a can of compressed air, and one of those LCD screen cleaning kits you buy from an Electrical retailer. Blast off any dust or debris then use the cleaner and supplied microfiber towel. The LCD screen cleaning solution dries quickly and it doesn't run because it's sort of like a gel spray substance (this is good because you don't want it running down into the edges).
    DO NOT press hard when wiping it with the cloth and solution and hold back the nozzle from the compressed air about 20-30cm. It works every time for me and mine is very clean and scratch free.
    I know it sounds over the top, but considering it's an expensive dash, I don't want to risk it.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
    Mar 2010
    Townsville, QLD
    Screen protectors
    Looks like you can get screen protectors for the info display and infotainment unit:
    http://www.protectionfilms24.com/pro...n&modell=31682
    Coming soon: MY19.5 Tiguan 162 R-Line + S&V White
    Now: 2017 MK7 GTI|Reflex Silver|Manual|Poverty Pack
    Gone: 2010 Golf VI GTI|Carbon Steel|DSG|MDI|Leather|18" Detroits|APR Stage 1
