Results 1 to 6 of 6
Thread: Windscreen Wiper Blade Change
    Sep 2017
    Hi All,
    I'm going to ask a stupid question. How do you change the windscreen wiper blades on the B8 Passat?
    When I try to lift the Wiper arm, the bonnet gets in the way.
    Any help would be great, as I'm sure there is a simple solution.
    Thanks
    Mine - Mustang GT MY20 - Carbonised Grey - "Nicky"
    Hers - T-Roc 140 TSI Sport MY21 - Reveena Blue - "Rocky"
    Previous - Passat 206TSI MY17 - Night Blue
    Pacific Paradise QLD
    It probably tells you in that seldom read book in your glovebox that there is a service position that you turn ign off while wipers are moving to allow you to do that.
    It certainly does in both of mine
    Sep 2017
    Thanks
    Mar 2017
    Tasmania
    Once you have switched off the ignition, flick the wiper stalk for a single sweep. The wipers will stop in the "service" position.
    Jul 2012
    Bendigo, Victoria
    In mk5 Jetta, pulling wiper stalk down immediately after turning off ignition places blades in service position. May be different, but worth a try.
    Sent from my SM-G900I using Tapatalk
    Sorry. Just seen reply above.
    MY 09 JETTA 118 TSI 7 spd DSG
    Sep 2017
    Ahh, that's very easy then. Thought there would be a simple solution.
    Thanks all for your help
