Just found and removed one from my 2018 Arteon.
I manoeuvred it around with my finger and then used needle-nose pliers like Lucas_R - very carefully, was worried about tearing the bag, but it seemed in good condition and relatively tough. The hardest part was getting the bottom corners out, moved some of the silica towards the top and then pushed one corner in while gently pulling.
My reservoir also had Mit Silikat printed on the side also.
