Mine failed at 35k 2 years in Wolfsberg Alltrack Diesel - replaced under warranty
Passat Wolfsburg 2017
Mine failed at 45K.
VW replaced under warranty, eventhough the warranty had expired 4 weeks earlier.
Must have been a bad batch of water pumps, by the sounds of it.
MY17 Passat Alltrack Wolfsburg, Indium Grey, Sunroof
I agree about the wheel size on Wolfies. After reading this thread and others, I have just replaced the 19" wheels fitted to mine with a set of used OEM 17x7 B8 Passat rims with 215/55R17 tyres which I found on ebay. I'm very happy with the result. Better ride, less bump steer, less jittery steering. I'll probably replace these tyres with 225/66R17's when these are worn out. The rolling diameter would then equal the 19" original tyres, give a slight increase in ground clearance, and perhaps even better ride.
Having read the above threads, I might have been even happier with 16" rims. Perhaps in the next life.
Mine is just coming up to 30k km... i do have eric 5yr extended warranty...
225/60R16 98Y is available in the Pirelli Cinturato P7 (Which is the same 19" tyre fitted to the wolfy and has the same load and speed index, so insurance should be fine as its the same rolling diameter). Might have issues fitting over the brakes?
2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
2023 MY23 Nevada White Cupra Formentor VZx
2015 Carnival Yellow Honda S660
Damn, just had the all track in finally to see if we could fit the 16” wheels I had from the old car and it’s a no go. Needs more clearance and offset to work.
New roof box got mounted though, pretty happy with it.
Using it. Drove through 15cms of snow for a fe km and had a ball!
Hey Foxuppet,
Did you ever put 17"'s and larger tyres on your B8 in the end?
I am looking to do something simlar to what you did on your 1.0 Build. But I am aslo looking for a 1.5inch lift kit.
