Results 1 to 7 of 7
Thread: Brakes Passat B8
    Feb 2018
    Brakes Passat B8
    Hi,
    Can anyone technically minded tell me more about the brakes on the Passat B8 more specifically the R-Line.
    Are they from an Audi, how many pots, general specs
    Tried googling, not much info out there.
    Cheers, G
    Apr 2017
    belgrave victoria
    Quote Originally Posted by Goublin View Post
    Hi,
    Cheers, G
    You would most likely have 312mm front disc's and the 287mmish rears with single piston calipers that's what vw put on most cars of that type if you had the 206tsi it would be the 345mm front with 310 mm backs also single piston calipers
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    May 2007
    When you say R-Line, I am assuming you are referring to the 206TSI R-Line?
    As the R-Line Optional Package does not change the brakes on any other variant.
    The 206TSI R-Line has both front and rear ventilated Discs.
    F) 340mm x 30mm (vented)
    R) 310mm x 22mm (vented)
    Solid rear discs on the other variants.
    F) 312mm x 25mm (vented)
    R) 300mm x 12mm (solid)
    Feb 2018
    Thanks for the info fellas. Yes I was asking specifically for the 206 TSI
    Feb 2018
    sorry, just another question. Are they the same brakes on the Audi S3? the look like my mates but without the caliper clip. Or are they bespoke to the pasaat?
    Apr 2017
    belgrave victoria
    They will be the same all the parts are shared between Golf R and now 2019 GTI the 206 passat audi A3 and probably a few scoda models i don't know about
    Feb 2018
    Quote Originally Posted by Kachingg View Post
    yeah literally have all the above car badges on the brakes
