Hi anyone got the lowdown on changing the aircon to a tropical climate setting . Its just acceptable in comparision to my last drive a ford mondeo MB titanium which was litteraly a fridge in operation?
Sent from my SM-G935F using Tapatalk
What temp do you have it on?
Do you have it set to "AUTO"?
I personally have it set on 21 degrees (Passat) / 22 degrees (Jetta) and is fine.
Mind you, I have driven (owned) many Japanese cars and they have icy cold A/C and generally a temp of even 24 degrees is too cold...
Interesting you are coming from an MB Titanium.
I have personally owned 3 MC Titanium's (TDCi and EcoBoost) as well 2 MD Titanium's (TDCi and EcoBoost) and I would say all were similar to the Passat and Jetta (and all the other VW's I have owned).
What I would suggest if you are unhappy is to go to the dealer and get them to check the Refrigerant Levels and ensure all is ok from a "Hardware" perspective before you mess around with the "Software"...
I would rate the Arty as 2 gens ahead of the Ford on all counts with exception too a few things which bar one have been fixed with obd2.
Auto high beam mem and the like. Only o/s issue is the dub not reading out my sms messages & me being able to respond with a canned option.
MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
the voice command - "read text" will read the new sms messages received.
Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
The Passat is not like the Jetta is it where the top dash has a separate vent that needs shutting off for the other vents to blow more.
If you keep the top vent open it just pushes more cold air onto windscreen and doest seem to cool the cabin down at all until you close it.
