Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Aircon not cool
    Sep 2012
    the voice command - "read text" will read the new sms messages received.
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    The Passat is not like the Jetta is it where the top dash has a separate vent that needs shutting off for the other vents to blow more.
    If you keep the top vent open it just pushes more cold air onto windscreen and doest seem to cool the cabin down at all until you close it.
    Quote Originally Posted by Blackpaladin67 View Post
    Hi anyone got the lowdown on changing the aircon to a tropical climate setting . Its just acceptable in comparision to my last drive a ford mondeo MB titanium which was litteraly a fridge in operation?
    Sent from my SM-G935F using Tapatalk
    Blackpalardin67: Not sure about the B8 but it's cousin vehicle the Golf mk7 (both cars are built on a MQB platform) has a "wobble-plate" compressor that is designed to operate at 2 x set points: the "normal" setting allows for a basic capacity level cooling and "hot country" setting increases the capacity of the Air Con by lengthening the stroke of the compressor.
    If the B8 has the same system, it might be worth checking the setting on your car. All that's needed is a diagnostic cable like VCDS, or OBDeleven - like this:
    See Edit below
    For VCDS cable owners
    For OBD11 dongle owners
    Dec 2017
    QLD Australia
    See Edit below
    Superb Don very much appreciated as it was like 39c here today.
    Jun 2007
    Took out my air con filter from front passenger foot well yesterday, washed and dried made a significant difference in cooler/quicker bringing temp down , didn't think it was that dirty but has made a difference.
    Apr 2009
    Melbourne, VIC
    Good quality window tint will also make AC work a lot better.
    Apr 2009
    Melbourne, VIC
    Where can one obtain a VCDS or OBDeleven?
    Sep 2012
    OBDeleven is available through this site. There are some other sites that sell it too.
    OBDeleven PRO Diagnostic System – Audi, Skoda & Volkswagen – AutoInstruct
