Results 1 to 5 of 5
Thread: 2015 b8, which fuel additives I can use?
    Jul 2015
    Melbourne VIC
    Just wondering do I need to use the additives, ie. Injector cleaner or fuel system cleaner after nearly three years use.
    Or just two tanks of BP 98#?
    Thanks fellows.
    Feb 2013
    Perth, WA
    Quote Originally Posted by ylzhao View Post
    Thanks fellows.
    I'd recommend running 98 all the time, but 95 would do every day. Injector cleaner won't do very much and regardless, it's part of a normal service (unless you're doing that yourself). A couple of tanks of 98 won't do much at all IMO.
    So in short, if you sevice it yourself then run some cleaner through (it won't do much), otherwise, leave it for the person that next services your car.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
    Jul 2015
    Melbourne VIC
    Quote Originally Posted by Wynnston View Post
    thanks for sharing Wynnston. I do service every year as requested by the booklet at dealership. it is running at 98# all the time (thanks for 711 fuel app with mock gps). the reason i asked, as i noticed recently it is running with bit lack of responding with accelerating.
    HIS: MY2016 VW Passat B8 132 TSI, white
    HERS: MY2018 Kia Carnival Sli 3.3 V6, black
    Apr 2018
    Not sure about the 711 98 fuel now but when I delivered petrol for a living I knew that the Caltex 95/98 had exactly the same additives in it. I've delivered the additives seperately to be blended a few times to a terminal. The 711 98 back then was just a base Shell 98 without the good additives in it.
    There is no difference between 98 and 95 as far as performance goes unless your car is tuned specifically for 98 or unless it has twin timing tables where 98 fuel will stop it reverting to the lower table.
    For mine I just used Big Brand 95 fuel once I got rid of my performance cars. Never had any fuel issues.
    Passat Alltrack Wolfsburg Edition My18
    Jul 2007
    Brissy
    I always run 98, 7-11 brand, but I noted some detonation on acceleration, just a smidge mind you.
    I ran a bottle of injector cleaner through and it has completely fixed the detonation issue. No more marbles in a can.
    About $4 on special at super cheap.
    So yes the cleaner stuff can be good.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
